hitting rev limiter after tcu tune
I instructed Jerry to do the following;
S = More aggressive and standard (Faster Gear change, hold revs, higher RPM)
C = Run almost standard mode with any changes he recommends.
M = Full Manual Mode
So far my findings...
S = The torque converter locks up quicker and harder, you feel it change gear quicker.
C = Almost like original s-mode, when coasting the rpm will drop lower to save fuel.
M = Much more responsive and it locks up the torque converter harder.
Because generally the torque converter locks up harder it easier to loose traction when changing gears on accelerating hard.
Will update again later when I get the chance to try it longer term..
Many thanks to EC Jerry & Adam..
