hitting rev limiter after tcu tune
I was told by Eurocharged that I was hitting a torque limiter. It would be good if they could give more info on this, but so far that's all I know.
I'm not sure if there is a fix for it so I just usually shift before 6.5k to avoid hitting this limiter.
This doesn't sound right...
Flame suit on just in case.
Could someone please explain what the torque limiter is?
1. getting the remote ECU cable and reflashing the ECU to lower power output at the 2-3 shift and maybe other points.
2. if that does not work then the TCU will need to be sent back.
I really like the TCU tune and I'm hoping I don't have to go back to stock.
Hopefully, they get the TCU and ECU sorted out with regards to AFR readings.
I am going to dyno my car Tuesday and get AFR readings with my current versions of the ECU and TCU software. Hopefully, I get a good AFR throughout the rev band.
I will for sure post them up by Tuesday night so everyone can see. I am also curious as to compare my WHP with that of Eurocharged's graph on their Dyno Dynamics. I will be on a Mustang dyno so it should be some what similar.
Edit: I found this over at the Crossfire forums. Looks they one of the guys over there is having the problem as well.
http://www.crossfireforum.org/forum/...v-limiter.html
