C32 Transmission Flush?
c280 1998, 2002 C32, 2000 Ford Excursion
About to do this the first time on my c32. any tips? should I replace the filter?
Mine 03 C32-Hers 04 c32
is there a how to on this? I just picked up one of those thingies that suck the fluid out, I did not no we had a filter. is it hard to get to?
W203 slightly modified
There are several areas to drain. One is the main sump - that is where the filter is. The other is the transmission cooler line that runs out to the front of the car through a small transmission radiator.
Then also you have fluid in the torque converter. They usually have a drain plug.
A really good flush is quite a lot of work and getting the refill levels right can take some patience.
Make sure the little caps on the transmission lines at the radiator are oriented correctly. The metal c shaped clip goes into a slot not only on this cap or fitting, but the fitting's slots have to be alligned with the slots on the actual fitting/tube on the radiator itself. I made a huge mess of my garage as i started up my car for the first time (after i had everything bolted back together of course) because the c- clip wasnt going throught the slots on the radiator tubing and therefore the cooler line came out and oil spurted everywhere...
C32/C55 AMG
Ok, so I finally figure out how to install the upper trans cooling line in to the radiator and it has been problem free.
A few pointers so that you don't go crazy and question your work.
If you pull out the upper cooling trans line from the radiator, make sure to push it all the way in and the clip installs only one way. Take a picture of it before taking it out. I installed on three separate occasions and each time there was no leak. I would drive it for a day and then I'd have trans fluid pouring out of the car. Make sure to constantly check the connection to see that it's been done correctly. That stupid connection cost me a day at work and having to buy trans fluid at the dealer @$25 liter.
When you fill the trans fluid in the fill tube, make sure to pour very slowly. Since the tube is so small, it tends to overflow if you pour too much at one time. The funny thing is that the fluid flows down the tube to the transmission and comes out around the trans pan. So it appears that your transmission pan is leaking, when in reality it's over flow from the fill tube. I couldn't figure it out, until I actually saw it. I ended up having to do triple the work just because I thought my trans was leaking and all it was, was that the fill tube was overflowing.
The job is very easy and I would recommend doing it. There area various places where you can buy the recommended fluid cheaper than what it can be found at the dealer. Make sure to buy a few spares for just in case.
More info: https://mbworld.org/forums/c32-amg-c...ush-today.html
