My New Project
Old Feb 17, 2012 | 08:44 PM
german32er's Avatar
C32 & C63PP, 203CL
Originally Posted by Robert AMG
after all i have to make customs rods.....
yes, with your planned composition too
you lost 1.3mm with the 84mm crankshaft, 148,5mm rod (origi C32/M112 3,7) and the 55k piston...
for normal compression you must mill off the block to 1.3mm, or you need longer (1.3mm) rods....
Old Feb 18, 2012 | 06:00 PM
Karimsc32's Avatar
2002 C32 AMG
hi robert am karim ali's friend i have a question to ask you why dont you put the e55 kompressor on the stock c32 engine wouldnt that allow you to raise the boost and therefore make more power ??
Old Feb 25, 2012 | 03:58 PM
Robert AMG's Avatar
Cls63 & C32
This week we didn't work on the car, i was busy and i got a baby
'German32er' yes i'll mill off the block and it's easy, cheap and alot cheap than making customs rods. i'll take 1mm off the block instead of 1.3mm to lower the compression to 8.78 and to make place for bigger pulleys.
Karim to go with the 55 SC on the C32 engine there is big chance to went a lot higher then 1.5 bar boost, it's risky, we have to go with bigger pistons to lower the boost.
Old Feb 25, 2012 | 05:47 PM
AMG Sleeper's Avatar
2005 C55 AMG, 2010 VW GTI (Stage 1)
Originally Posted by Normandie4life
Finally someone crossing the lines and doing something BIG. Good luck man hope everything works out. Most def interested to see results
+1 ... great and unique idea, excited to see it all come together. Keep us posted!
Old Feb 26, 2012 | 07:28 AM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Robert, congrats on the baby.
Old Feb 26, 2012 | 07:41 AM
320 dreamer's Avatar
2003 porsche 996 turbo
boy or girl? did you hand out wrenches instead of cigars?
Old Feb 28, 2012 | 01:41 AM
  #32
german32er's Avatar
C32 & C63PP, 203CL
'German32er' yes i'll mill off the block and it's easy, cheap and alot cheap than making customs rods........
yes, mill is cheap.
have you think about adjustable camshafts wheels....
you need it, if you mill off so much, to set absolutely correct camshaft timing
you build now an "cheap" () 3.7L.
to build the 4.0l you need only the crankshaft and this costum rods more.
if you look at your total expenses, which would not be soo much more, and you would have 300cc more ....
a high-end build engine was never cheap
Old Mar 1, 2012 | 05:33 PM
  #33
Robert AMG's Avatar
Cls63 & C32
Thanks guys it's my second girl!
Well this week we make all calculations for compression ratio, and everything is solved and i didn't payed anything, tomorrow i'll make a detailed post about it, no milling of block! the 55k pistons will not work!
Some pics:
My New Project-imag0501.jpgMy New Project-imag0503.jpgMy New Project-imag0505.jpg
Old Mar 4, 2012 | 06:11 PM
  #34
Robert AMG's Avatar
Cls63 & C32
UPDATES:
I mentioned before that the 55K pistons will be used in this project, so after some work and research the 55K pistons will be swapped with 55 N/A pistons from W209 or C55, reason:
Compression ratio formula:
CR=(D + PV + DC + G + CC) / (PV + DC + G + CC)
D = Displacement
PV
= Piston Volume
DC = Deck Clearance Volume (distance between the top of the piston at TDC and the deck of the block)
G = Gasket Volume
CC = Combustion Chamber Volume (engine heads)
If i started by calculating 55K engine:
let's take PV, DC, G and CC as one factor V and try to calculate V for 55K engine (DC is same for all 112/113 engine, G also the same, CC is also the same only 55k differ by a very little volume-assuming the same now we can get the difference between piston volume by calculating V)
formula now is: CR= (D+V)/V
D for all 55 engines=3.14*bore*bore*stroke/4= 3.14*97*97*92/4= 679864mm2
CR=9=(679864+V)/V so V 55k= 84983mm2
now for 37 engine, D = 3.14*97*97*84/4= 620746mm2
if we want to use the 55k pistons in the 37 engine the 55k piston will be lower by 1.3mm from deck block, so the volume made by 1.3mm is 3.14*97*97*1.3/4=9607mm2
CR for the 37 with 55k pistons will be= (D37+V55k+V1.3)/(V55k+V1.3)=
=(620746+84983+9607)/(84983+9607)= 7.56
also the heads of 55k(Combustion chamber) are a little bigger from 37/55NA so this nb will vary a little up to 7.7 or 7.8.
so this nb is very low for compression ratio, we have a choice to mill the block 1.3mm and we get CR at 8.3 to 8.5 and maybe the camshaft timing also will deffer by milling the block 1.3mm.
so we did not go with this route, we went with the w209 55 pistons,
W209 55/C55 has 11.0 as CR and the pistons are also lower by 2mm from deck of block.
CR w209 55 = 11= (679864+V 55)/V55, V 55= 67986
V of 2mm= 14780
CR of 37 with 55 w209 pistons = (620746+67986+14780)/(67986+14780)
= 8.5
Result if we use 55 w209/C55 pistons we get CR = 8.5 and we will not touch the block or camshaft timing. and this is what i want with lower CR for making room for bigger pulley and more power.
i swapped the 55K pistons with 55na ones without paying anything, so the problem is solved (cheap). Also 55 n/a pistons are less weight than the 55k:
55k= 582g
55n/a w209= 532g
C32= 512g
55K on right w209/c55 on left
55K chamber
w209/c55 chamber
37 chamber same as W209/c55
double spring valves of 55k installed
Old Mar 4, 2012 | 06:56 PM
  #35
why not bore the engine bores and then sleeve them removing the nickasil lining and then allowing you to use a high quality ross piston in any compression ratio you choose? im following with interest but it seems your taking the hard road to do this.
in the crossfire world there is a turbo charged pushing a s/c engine with 8 to 1 compression pushing 30 psi and still tuning for power. all on a 3.2 block
Old Mar 4, 2012 | 10:26 PM
  #36
macbryanie's Avatar
Porsche 2004 911
Old Mar 10, 2012 | 01:04 PM
  #37
Robert AMG's Avatar
Cls63 & C32
Engine in the car, pics:
My New Project-imag0529.jpgMy New Project-imag0535.jpgMy New Project-imag0538.jpg
Old Mar 10, 2012 | 01:48 PM
  #38
loudandheard's Avatar
C32/C55 AMG
What has to be done next?
Old Mar 10, 2012 | 02:23 PM
  #39
Robert AMG's Avatar
Cls63 & C32
Some cutting/welding for the inlet/outlet of the SC, also in the firewall, fuel, then engine starting, looking at boost, tuning... then if everything went good top mount IC/cooling, dual exhaust, and maybe 55k transmission.
Old Mar 10, 2012 | 02:35 PM
  #40
silverjimm's Avatar
04 Crossfire MB 5.0L M113 V8 6spd, 05 Bagged SRT6w/55K AMG V8 ,2016 C300 Sport
Very Awesome project!
Old Mar 11, 2012 | 10:47 AM
  #41
carlosfernandez's Avatar
SL500 2003 previous/ E350 2007 actually
Keep us posted !!please
Old Mar 11, 2012 | 11:11 AM
  #42
WaveyKat's Avatar
Something Slow
can i have your long tube headers? :-)
Old Mar 11, 2012 | 11:55 AM
  #43
mikata's Avatar
Mercedes CLK 320 W209
Subscribed. Awsome project.
Old Mar 12, 2012 | 12:29 AM
  #44
AMG3.2's Avatar
C63 AMG, P30
So sick! Can't wait until its done to see some numbers.
Old Mar 12, 2012 | 12:57 AM
  #45
macbryanie's Avatar
Porsche 2004 911
+1 Insane...
Old Mar 12, 2012 | 01:17 PM
  #46
EVOII_Racer's Avatar
Mercedes Evo II
damn very nice Sir! Btw what kind of sick pipe are these! For sure not stock manifold!
Old Mar 12, 2012 | 01:44 PM
  #47
Robert AMG's Avatar
Cls63 & C32
Eurocharged long tubes(in my signature).
Old Mar 12, 2012 | 03:33 PM
  #48
WaveyKat's Avatar
Something Slow
are you gonna sell them? those sick LT headers :-)?
Old Mar 12, 2012 | 05:02 PM
  #49
Robert AMG's Avatar
Cls63 & C32
I think Eurocharged made only 3 to 5 long tube headers before they stopped production of them.
video when checking compression ratio:
Old Mar 12, 2012 | 06:53 PM
  #50
C32/C55 AMG
Couldn't read the compression in the video, did come out the same as your calculations?
