coolant loss
Old Mar 4, 2012 | 03:53 PM
jason 1432's Avatar
c32 amg
coolant loss
Ther are alot of threads on this subject but i just dont kno where to start.
I have to fill my coolant once a month and I know this is not normal.
I checked my coolant cap and heat exchanger for leaks no sign of any thing. can any body tell me my next step or any ideas on what it can be.
thanks
Old Mar 4, 2012 | 03:56 PM
WaveyKat's Avatar
Something Slow
surge tanks, are you seeing coolant spills around the bottle?
Old Mar 4, 2012 | 04:05 PM
jason 1432's Avatar
c32 amg
do you mean the coolant tank
Old Mar 4, 2012 | 07:18 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
I think he means that you might have a leaking intercooler core (not heat exchanger). The sure-fire test is to remove your cast AMG manifolds, and check for a buildup of dried coolant residue. I believe boohooramblers had an excellent thread on this topic.
I was losing coolant recently as well, and suspected the IC core. Turned out to be a small tear on one of the upper coolant hoses instead. Good luck with your diagnosis.
Old Mar 4, 2012 | 10:42 PM
jason 1432's Avatar
c32 amg
Thanks for your help I took apart every thing today and found massive amounts of biuld up. its all full of dried coolant now waht do I :-(
Old Mar 5, 2012 | 06:41 AM
c32AMG-DTM's Avatar
Well, to fix the root cause, you'll need to source a new intercooler.
Conventional wisdom suggests the OEM part is best - there are no successful aftermarket alternatives that I'm aware of. From memory, I think the IC runs $800-$1k or something like that.
Replace the IC, clean out the cast manifolds, and you should be good to go... assuming there's nothing else wrong.
Old Mar 5, 2012 | 09:14 AM
jason 1432's Avatar
c32 amg
Thanks man I guess I'll start looking around for one
Old Mar 5, 2012 | 10:17 AM
OverDrive's Avatar
Volvo
I can sell you a used one for 400.00 + shipping, My first one was bad, So I ordered an aftermarket one, but they also included a OEM one for free, The aftermarket didn't fit, so I installed the OEM one, and used it for 6 months until I could fix the aftermarket one.
So this one is about 6-12 months used, works fine, no leaks
Old Mar 5, 2012 | 10:55 AM
jason 1432's Avatar
c32 amg
I thought they didn't make after market intercoolers
Old Mar 5, 2012 | 02:11 PM
c32AMG-DTM's Avatar
Code 3 tried to make them for awhile, but IIRC had fitment/quality control issues. I don't know anyone else that has successfully made (or improved) upon the OEM one.
Old Mar 5, 2012 | 02:12 PM
c32AMG-DTM's Avatar
Oh, forgot to mention - OD's offer above is a good one; if the part is as advertised, I'd go that route if I were you.
Old Mar 5, 2012 | 04:34 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
SECOND that, Dan is an awesoeme guy, stand up....and this price is a steal, so you should jump on it.
I just paid $920 plus shipping on parts.com.
Old Mar 6, 2012 | 11:28 AM
jason 1432's Avatar
c32 amg
I think this is some thing to buy new ?
Old Mar 6, 2012 | 01:13 PM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
It is up to you. The diff is over $500. There is no end to how much you can spend on these cars. Check this out: http://www.needswings.com/Intercoole...ermalIC32.aspx
Old Mar 6, 2012 | 01:18 PM
jason 1432's Avatar
c32 amg
I kno I looked at the same thing last night but I think im just going to go new at Mercedes becuase I plan to keep this car for a while and atleast I'll know it's brand new
Old Mar 6, 2012 | 04:41 PM
2002 C32, 2012 S550
BTW, when I initially ordered mine, they said it was backordered and might take 2 weeks or longer, but it ended up coming in a week.
I would have bought Dan's IC, but I didn't know he had it till after my new IC was already shipped.
Old Mar 6, 2012 | 09:40 PM
OverDrive's Avatar
Volvo
My bad lol, I should have check the forums sooner....
Old Mar 6, 2012 | 09:55 PM
2002 C32, 2012 S550
No worries brother, I appreciate the offer. It's my daily, so I placed the order pretty quick.
