ecu tuning
Thanks a lot.
My friend tuned the ECU and the engine light came on. (The car acted find for 200 miles and then the light came on).
The gearbox is now acting weird...
Could this be due to the ECU tuning?
Thanks a lot!
Thanks a lot!
what do you mean by pulling the codes? If you mean change the ecu maping yes. But the issue happend 300miles after.,the engine was runing great before
[QUOTE=loudandheard;5206389]+1
You need to get an obdii code reader to see what malfunction code caused the check engine light to come on. Any noticable problems with the engine when you are driving the car?[/QUOTE ok thanks. Yes at one point no power at all, 60mph max speed! Now back to normal just the engine light...
e36 318i, 2004 sti
Well once the check engine light has went off you will have it stored. I would do it soon because once you do enough warm up cycles it can be erased. You need to find at least a decent scanner to see what the code is. Also if you get your hands on a good scanner you can see the code and pull up freeze frame data to see the data of everything during the time the MIL was activated.
