Check Engine Light Not Resetting Despite New MAF Sensor
Old Jun 10, 2012 | 07:45 PM
Rahulio1975280C's Avatar
2021 GLE450, 2005 C55, 1990 500SL, 1991 300E, 2006 BMW M5
My 2005 C55 just crossed 90,000 miles, and as a result, I decided to do a tune-up.
New NGK spark plugs, Beru wires, Mann air filters... etc.
As part of this tune up, I decided to go ahead and get a new Mass Air Flow sensor. (MAF)
I purchased a Beck Arnley unit, part number 18452-05218068 from PartsGeek.com.
When I installed the new MAF, I accidentally forgot to plug the new sensor in. As a result, the C55 ran rough upon the first start since the installation of the new MAF. I quickly realized what I had done, stopped the car, plugged the sensor into the harness and restarted the car. It ran smoothly and I assumed the MAF swap went as it should.
The next day, the check engine light illuminated on my way to work.
I assume the light came on since I started the car with the MAF unplugged, but now that the new MAF is plugged in, I read from a post that the check engine light should go away by itself.
Has anyone on this forum had a problem with a Beck Arnley MAF when equipped to an AMG'ed M113 (C55 engine)?
I have not done anything else to the car yet, since I want to resolve this issue first before changing the spark plugs and wires.
On a side note, I did order an OBDII scanner, finally!
Old Jun 10, 2012 | 07:55 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Scanner...
Old Jun 10, 2012 | 08:20 PM
Scanner, reader... same thing!
It will arrive on Wednesday of this week according to Amazon.
Old Jun 10, 2012 | 09:19 PM
Viper98912's Avatar
I have 105k, I should probably look at changing out the plugs, etc. My only issue is that the car runs perfectly just like when I bought it at 46k, so I fear trying to make a change and having something go wrong. If it ain't broke don't fix it, but at the same time if you don't do preventive maintenance then it can all go to heck.
Old Jun 10, 2012 | 09:52 PM
MAF Variety
Hmmmm, I am starting to think that maybe AMG cars require slightly different MAFs than what a typical Mercedes-Benz engine would accept.
Case in point:
PartsGeek lists the following MAF choices when searching for a 2005 C55:
Choice 1:
Bosch Air Mass Meter
Retail Price: $414.00
Your Price: $182.85
Part Number: W0133-1601501
Condition: New
OEM
Choice 2:
A1 Cardone Air Mass Sensor
Your Price: $158.85
Core Price [?]: $28.80P
Part Number: 18452-05004975
Notes: Mass Air Flow Sensor -- Remanufactured
Condition: Remanufactured
Choice 3:
Beck Arnley Air Mass Sensor
Your Price: $163.85
Part Number: 18452-05218068
Notes: Mass Air Flow Sensor -- New
Condition: New
Choice 4:
Bosch Air Mass Sensor
Your Price: $134.85
Part Number: 18452-05219116
Notes: Air Mass Sensor - New
Condition: New
So as you can see, there are 4 choices, two of which are manufactured by Bosch.
One thing that totally slipped my mind was that only Choice 1, has the OEM designation. This leads me to believe that the Beck Arnley unit I purchased is not the exact MAF that I should be using. The sensor used in the Beck Arnley unit may have a differently scaled signal or have something largely different than my stock MAF unit. I am going to wait until my OBDII reader arrives before I consider an RMA. My commute is about 25 miles each way, so if the check engine light is still on by Wednesday, I will be pretty sure the ECU does not like something about the Beck Arnley MAF.
Old Jun 10, 2012 | 09:56 PM
The main reason I am changing out the spark plugs is due to a slightly rough idle. Rough meaning + or - 50 RPM at times like initial cold start or sitting at a light.
If your engine is still smooth as butter, then I guess there really is no reason to change it...
Old Jun 10, 2012 | 10:41 PM
Just went for a quick test drive to see if the CEL would clear up or if I would notice any other differences...
CEL is still not gone, but something I did notice is that the transmission up shifts a hell of a lot faster and my gas mileage is horrid.
I will still wait until Wednesday and get the actual codes out of the car with the OBDII reader, but I am leaning toward this Beck Arnley MAF sensor being the incorrect part.
Old Jun 10, 2012 | 10:48 PM
Viper98912's Avatar
Put the old one back in, just clean it out with MAF cleaner and call it a day.
Old Jun 11, 2012 | 01:07 AM
MarcusF's Avatar
2002 CLK430
OP - An NA 55 uses the same MAF as any other ME 2.8 V8. You can confirm this by looking at your original part. Two part numbers are stamped on the side of the OE MAF; the MB part number and the Bosch part number. The numbers you're listing are SKU numbers rather than Bosch part numbers. The correct Bosch part is 0280217810.
Old Jun 11, 2012 | 04:41 AM
desired_speeds's Avatar
2007 SL55 AMG
If all else fails, get a bosch unit. That beck arnley unit may be throwing the code.
Old Jun 11, 2012 | 12:14 PM
mikekuriger's Avatar
2010 C63
I had to get the computer reset when I changed my MAF.
Old Jun 14, 2012 | 10:47 PM
Don't Buy Beck Arnley!
Okay, time for an update...
OBDII scanner arrived on Wednesday.
I interfaced with the car and was able to pull two codes. I do not remember the exact codes at this exact time, but they both said "Bank 1, mixture too rich" and "Bank 2, mixture too rich". (Or something very close to these descriptions.)
Obviously, these are MAF (Mass Air Flow) sensor related. (Or rather related to when I started the car with the new MAF unplugged.)
I decided to clear the codes using my nifty new OBO II tool. The check engine light turned off, and I went for a good 30 minute test drive around town. The car appeared to be behaving very well, my gas mileage was back up to normal levels, no ultra quick up shifts anymore either.
The car went into the garage with me thinking that the problem was gone...
Nope... that would be too easy!
Check engine light returns on my way back from lunch today. At the end of my lunch break I checked to see what the codes were, and the same two codes had returned.
When I got home I double checked my installation of the MAF to ensure there were no leaks or folded seals around the MAF ducting areas. No issues found, I double checked the connector going to the MAF to ensure it was seated all the way and it was perfectly fine.
I am going to RMA the new Beck Arnley unit, reinstall the old OE Bosch unit, make sure everything is back to normal, then get a proper Bosch replacement.
So boys and girls, I just got shot in the face by the
"If It Ain't Broke... DONT FIX IT" troll.
Just my luck.
Old Jun 24, 2012 | 09:14 PM
Replaced the cabin air filter, old vs new at 90K miles, never been replaced before.
Rear of engine, MAF removed along with elbow housing.
New Beck Arnley next to old Bosch MAF unit.
Picture of the elbow connector. MAF connects to top port, bottom port connects to throttle body.
Since I had everything apart already, decided to clean the throttle body. Everything had a light coat of oil/dust/dirt.
Using a shop rag, got it to this point.
Another shot of the elbow connector, notice the greenish tint, I think Mercedes-Benz used some kind of sealant around the rubber seals... anyone have any ideas what to replace it with, if anything?
Bring in the Q-Tips!
The best I could get it.
Transferring the MAF mount ring back to the old Bosch unit.
Below the Chrysler text is the PVC vent hose that makes the throttle body get oily over time. Be sure to reconnect it!
MAF back in.
Another picture of the collar mount ring that goes around the MAF unit.
Does everyone's right intake hose have this crease?
Old MAF is back in, check engine light reset, been driving 50 miles a day for the last 5 days, no CEL light so far. Returning the Beck Arnley unit, getting a new Bosch unit.
Old Jun 24, 2012 | 09:46 PM
Viper98912's Avatar
At least you found the problem.
And yes i think mine has that bump in it too
Old Jun 24, 2012 | 10:27 PM
betrezra's Avatar
C63 507 AMG DA Car #19
Beware of aftermarket MAS replacements.
Old Jun 26, 2012 | 01:47 AM
MarcusF's Avatar
2002 CLK430
Originally Posted by Rahulio1975280C
. . . . . .Another shot of the elbow connector, notice the greenish tint, I think Mercedes-Benz used some kind of sealant around the rubber seals... anyone have any ideas what to replace it with, if anything?
The dealer uses a lubricant on the sealing rings (both sides of the elbow and on the MAF where the air filter assembly fits) called "Naphtolen H". The MB part number for Naphtolen H is "000 989 01 60", and it has a current list price of $92 ($71.50 with the discount). Some people use a light film of 303 Aerospace Protectant instead. 303 Aerospace Protectant is about $10.
Old Nov 11, 2017 | 02:29 PM
Malachi Caley's Avatar
1997 mercedes e420
have 97 mercedes e420 maf sensor code came up p0100 cleaned maf sensor cleared code drove five miles shut car off restarted code came back ? do i have to drive it more for computer to go through drive cycles ? usually i clear code for a problem engine light doesnt come back on ?
Old Mar 20, 2018 | 03:10 PM
TwoPheat's Avatar
2001 C320 + 2002 C32 AMG + 2007 Range Rover SC
You cleared codes with what? 5 Miles is likely not nearly enough time/distance to drive the cycle, or hit all the speed and deceleration points. If you cleared it by battery or with a reader, then it should still take an entire cycle. Make sure you turn the car OFF (even remove key for a sec, to be sure) right after resetting, and start fresh. Otherwise the same codes may still show.
Old Mar 20, 2018 | 08:32 PM
Nokiemon's Avatar
CLK55 AMG, SL55 AMG, C55 AMG
You might want to check dates on some of these threads.
This one is six years old.
Old Mar 21, 2018 | 09:34 AM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
I thought the same, but he is answering a post only 5-ish months old.
