Problem with C55. Battery/Alternator Visit Workshop.
Old Jul 14, 2012 | 09:35 PM
GT-ER's Avatar
2005 E55 AMG
My friends C55 turned on a red display with the message "Battery/Alternator Visit Workshop". His car eventually ran out of energy from the battery and turned off. I told him to check out the alternator and he sent it to a mechanic and the alternator was bad and it was replaced with a reman and they installed a new battery as well. As soon as they turned it on it still had the error message. After a few tries the error message went away and the car was working fine....for one day. Now it has the message again and the voltage is low ( 11's ) with the car on.
What could be doing this? Is there a battery control module in this car? If so, where.
Old Jul 14, 2012 | 11:03 PM
wawy's Avatar
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
Has the voltage regulator ever been replaced? This may be a contributing factor to your friend's problems. The voltage regulator is a minor annoyance (well, major for some if you're stranded..) with C55s, E55s etc...
Here's a good thread: https://mbworld.org/forums/c32-amg-c...hop-error.html
...as well, there are many others....
Old Jul 14, 2012 | 11:38 PM
GT-ER's Avatar
2005 E55 AMG
Originally Posted by wawy
Has the voltage regulator ever been replaced? This may be a contributing factor to your friend's problems. The voltage regulator is a minor annoyance (well, major for some if you're stranded..) with C55s E55s etc...
The entire alternator, along with the regulator, was replaced. I'll read that thread to see if I can get any ideas.
UPDATE: The message is gone again...seems everything is normal again. This is weird. Let's see if it comes back.
Old Jul 15, 2012 | 12:16 AM
MarcusF's Avatar
2002 CLK430
It sounds exactly like the voltage regulator has worn out. It's a normal wear part that cost $25 the last time I changed mine. Here's a write up.
Old Jul 15, 2012 | 12:18 AM
GT-ER's Avatar
2005 E55 AMG
Guys, come on, you are not reading. I already stated the regulator was replaced.
Old Jul 15, 2012 | 12:22 AM
MarcusF's Avatar
2002 CLK430
Did the alternator come with a new regulator? It doesn't on a Porsche (both use a Bosch alternator) and it's common to move the old regulator to the new alternator. If it's not the regulator then I have no answer.
Old Jul 15, 2012 | 12:41 AM
GT-ER's Avatar
2005 E55 AMG
Yeah, it brought a new regulator.
Old Jul 16, 2012 | 12:18 PM
mikekuriger's Avatar
2010 C63
It's also not completely unheard of to have a bad "new" regulator.
Old Jul 16, 2012 | 02:50 PM
arekux's Avatar
2006 C55 AMG
wow a lot posts on bad VR lately i hope mine doesn't go bad i got almost 100k miles....
Old Jul 19, 2012 | 10:30 PM
GT-ER's Avatar
2005 E55 AMG
Car keeps giving problems. It'll work fine one day, the next it'll give the batt/alt message again. If the car is accelerated it'll work just fine afterwards.
The w203 doesn't have a battery control module or something? My car does.
