Eurocharged V6 Supercharger Pullies! Sale 65mm and 61mm
Old 10-23-2012, 04:38 PM
SPONSOR
loungn14's Avatar
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Hey Everyone!
Our Aluminum Supercharger pullies have arrived!
Your choice of 65mm or 61mm
SALE for $499 plus shipping! 30 days only!!!
Get them while they last!!!!
http://www.eurocharged.com/index.php...art&Itemid=153
Enter $499 sale in the comments section if the website is showing the old price!
Old 10-23-2012, 04:54 PM
Newzchspy's Avatar
PLAID
Originally Posted by loungn14
Hey Everyone!
Jake, any difference in how YOU tune between the two??? Do you recall the mm of Brandon's Code 3 unit???
Old 10-23-2012, 06:30 PM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
Any details on the 61mm pulley? Ball bearing size and rating? Who makes them? Who tested them? Is it more like the 185mm crank pulley?
Old 10-23-2012, 06:45 PM
AMG3.2's Avatar
C63 AMG, P30
Jake, I just looked at the Eurocharged page and it says the 65mm raised the torque to 388. How are these gains calculated? With a 20% drivetrain loss?
Also, what are the power gains with the 61mm? Thanks
Old 10-23-2012, 07:49 PM
WaveyKat's Avatar
Something Slow
can we Stack them?
Old 10-23-2012, 08:07 PM
Lenin's Avatar
Originally Posted by WaveyKat
can we Stack them?
Stack the two SC pulleys? JK.
I'm running the 181mm and the 65mm stacked. Things get hot quickly but I use the Code3 reservour so it's not that bad.
Old 10-23-2012, 09:46 PM
WaveyKat's Avatar
Something Slow
i have a Code3 E55 HE and a larger water pump i currently have the 185mm Crank Pulley just wanted to know if it was safe to run 65mm SC Pulley :-)..
also thinking about getting an expansion tank 2-5 gals maybe
Old 10-23-2012, 10:32 PM
Lenin's Avatar
I don't know of anyone that is running 185mm Crank Pulley and the 65mm SC pulley. You would be bumping against the boost limit in the ECU. The ideal situation would be 178mm crank pulley stacked with 65mm or 62mm SC pulley, assuming the heat is controlled with cooling mods.
Old 10-25-2012, 05:28 PM
Newzchspy's Avatar
PLAID
Jake did Lenin and YES, it did bump up against the boost limit of the C32 and also had fuel delivery issues. Your set-up is probably the optimal way to go, although I think that the 181 crank and 61 SC pulley will also bump up against the limits as well. Ask Jake, he's pretty much done it all with them.
Old 10-25-2012, 05:29 PM
Newzchspy's Avatar
PLAID
can we Stack them?
Sure, 181 Crank and 65 or 61 SC pulley may work. Note that Jake has done this and there were boost limit and fueling issues as well.
Old 10-25-2012, 05:59 PM
Lenin's Avatar
Didn't know that Jake ran the stack pulley setup. From what I remember he used a 190mm crank pulley at some point.
Old 10-26-2012, 05:55 PM
tw2
tw2's Avatar
2005 E55 AMG, 1991 MR2
Obviously aluminum is lighter. What are the advantages otherwise vs I assume stainless? Will aluminium stand up long term to the wear?
What boost is 61mm going to produce? I'm lazy I cannot be bothered getting corky bell's "supercharged" out of the cupboard to work it out for myself.
Old 10-26-2012, 06:33 PM
AMG3.2's Avatar
C63 AMG, P30
I'd also like to know.
Old 10-26-2012, 08:35 PM
Lenin's Avatar
61mm SC pulley would be about the same as the 185mm crank pulley. With everything else being stock plus EC tune and you should be at 22 PSI at 6500RPM.
Old 10-27-2012, 03:03 AM
jturkel's Avatar
02 C32 AMG
+1
Old 10-28-2012, 07:19 PM
chris.bachman's Avatar
a car.
Got my 61MM, will post results after I put it on.
Old 10-29-2012, 01:50 PM
Newzchspy's Avatar
PLAID
My concern with the 61 is NOT overboost issues, BUT proper belt wrapping and slippage issues. I don't know how much its been tested, BUT I believe that Brandon at Code 3 had at one time done a 60 and it was slipping like crazy because of wrap issues.
Old 10-29-2012, 02:35 PM
Lenin's Avatar
Have you considered using NeedsWings Pulley Saver Kit? It does cut down slippage.
Old 10-29-2012, 04:06 PM
Newzchspy's Avatar
PLAID
I've been running their kit for about 4 years now. I am NOT sure that their PSK will help with belt slippage in this case since the amount of surface area on a 61 is less than the 65. It very well may work, BUT I'd love to see it in operation before biting the bullet on this one. Jake and Jerry have always done nice work and I am hoping that the 61 really pans out for C32 owners (and SRT-6 too). This would be MY solution versus going with a stacked version. I don't like the higher accessory speeds on the stacked units. Bearing life is definitely reduced on the crank pullied units.
I know that on the Kleemann, a 5 mm reduction really brought on big boost gains.
Old 10-29-2012, 04:40 PM
Lenin's Avatar
Good luck. I agree with you other point regarding higher accessory speeds not being desirable. I'm still waiting for answers to simpler questions I posed in #3 above. The rating of the bearing is a concern for me since it has to be smaller than OEM. Can the bearings be sources as easy as the OEM? How much? Anyone ran with it for 5000 miles?
Old 10-30-2012, 12:37 AM
Ken311's Avatar
E55 AMG, Porsche 911 SC
need more info on the 61mm!
Old 10-30-2012, 01:55 PM
FUBU's Avatar
SRT-6
I ordered mine yesterday and am looking forward to the install.
Have the PSK + supercooler + high speed idler pulley. This is going to be freaking awesome.
Old 11-06-2012, 08:56 PM
JUAN CASAUS's Avatar
2005 E55 AMG
Has anyone installed and tested this yet?
Old 11-06-2012, 09:48 PM
2005 E55 AMG
I have the 65mm I'm more interested in the 61mm. Sorry for not being clear.
Old 11-12-2012, 05:21 PM
dokotela's Avatar
02 W203 C32 AMG, 00 W202 AMG, 98 W202 C23K, 98 W202 3.0T, 97 W202 C23T, 93 W201 AMG
Following this....need some results already.
Anyone completed this?
Quick Reply: Eurocharged V6 Supercharger Pullies! Sale 65mm and 61mm
