steering rack HELP
Old Jan 23, 2013 | 01:51 AM
emin30's Avatar
C32
steering rack HELP
Need to replace the steering rack, I want to know whether the steering racks are compatible with Part Number (2034603300,2031101100,2034605200,2034601300), with the number that is on my car, which indicated Part Number 2034601100 Body number WDBRF65J93F325756 help
Old Jan 23, 2013 | 10:37 AM
precisionmike's Avatar
2003 C32
What are the symptoms of a back steering rack? I have a "clunk" up front when I go over bumps. I was thinking it was a ball joint, but I read of back racks in the W203. Sorry, not looking to jack your thread.
Old Jan 24, 2013 | 02:03 AM
emin30's Avatar
C32
The back of steering rack that you have in mind? I have a damaged steering rack, it is a little bent, so the steering wheel playing cornering
Old Jan 26, 2013 | 02:47 PM
ruben65's Avatar
Does it feel like you need to turn the steering wheel more to make your normal low speed turns, like their is play in the steering wheel to rack response?
Old Jan 26, 2013 | 04:19 PM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
2034603300,2034605200,2034601300 are all from C32s. They are not for your VIN# but they will work just fine. I don't see 2031101100.
Old Jan 26, 2013 | 11:44 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
You should run your vin through EPCnet and get the part number verified.
Old Jan 27, 2013 | 07:18 AM
Lenin's Avatar
What do you think I did for him?
Old Jan 27, 2013 | 09:23 AM
jneal3110's Avatar
04 C32 AMG (sadly sold), 05 CLK55 Cab, 08 R350 4Matic, 15 GLA250 (sadly bought), 75 VW Westfalia
My steering has a little play in it but it's not the rack, it's the intermediate shaft; I can see it when I put the car on a rack and while looking at everything from the column down to the wheels I had a buddy turn the steering wheel through its play, and I could see the intermediate shaft sort of move out of axis before stiffening and then turning the rack. Had a dealer tell me it was the rack, its clearly not and I would've been seriously irate had I dropped the $3200 they told me the job would cost. Racks do not typically wear out despite all the talk otherwise; ball joints, u-joints, etc wear sooner and are the more likely cause for play.
Old Jan 27, 2013 | 10:06 AM
kjb55's Avatar
Completely missed that.
Old Jan 28, 2013 | 01:25 AM
emin30's Avatar
C32
At high speed is very noticeable, and when you enter a corner, the steering wheel trying to turn it back and pulls often
Old Jan 28, 2013 | 01:41 AM
emin30's Avatar
C32
are you sure?
Old Jan 28, 2013 | 09:58 AM
Lenin's Avatar
are you sure?
Not even a "thank you"?
Old Jan 29, 2013 | 02:38 AM
emin30's Avatar
C32
thank you brother
Old Jan 29, 2013 | 11:53 AM
Lenin's Avatar
NP. I checked these part numbers against my EPC and they are all listed for C32. Have your dealer check them without the VIN. I'm traveling this week but should be back by Friday and can send you a screen print from my EPC.
Old Jan 30, 2013 | 12:48 AM
emin30's Avatar
C32
Thanks, would be very happy
