Will SL55 front and rear brakes bolt straight onto C32?
Old Feb 2, 2013 | 06:21 AM
varoom's Avatar
C32 AMG
There is a full set of sl55 front and rear brakes (calipers/discs/pads) for sale....
Will they fit straight onto my c32?
Cheers
Old Feb 2, 2013 | 09:43 AM
ChiCho55AMG's Avatar
W209 CLK55 AMG Kompressor, ATV BRP 800 CAN-AM
Cheers
I Have CLK55 04, same brakes as your C32. 4pots front 2 pots rear.
I Was about to put full set of E55(same as sl55) 8pots front 4 pots rear.
They will fit but not direct bolt,you will need to do some modifications as well if u have the 17 oem rims,then u have to change them to 18 rims.
If u can find CLK55 05-06 or CLK63-07 (NON BS) OR R171 SLK55 : 6pots front 4 pots rear then it will be plug and play...
Old Feb 2, 2013 | 05:45 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
no
Old Feb 2, 2013 | 07:00 PM
Originally Posted by Viper98912
no
Nice upgrade for ur rear calipers. Nice work bro
But as well nothing is impossible,everything could be swapped with mod,this is an exp for some big brakes upgrade with modification :
https://mbworld.org/forums/5097052-post12.html
Old Feb 3, 2013 | 07:57 PM
Viper98912's Avatar
Thanks man
Old Feb 5, 2013 | 11:30 AM
C_DirtyTwo's Avatar
a land yacht.
no
+1
Old Feb 5, 2013 | 01:56 PM
Thanks man
The upgrade you did is really nice for a daily driving,more nice look with less cost ! I've been thinking to put the E55 front and rears complete set(sure not plug & play, need to make mod ) and to find the 6/4 pots is somehow hard to find it over my place...So im thinking about ur upgrade,but let me ask you,did u feel any change in braking ? More better than before in how much % approx ?? Thanks
Old Feb 5, 2013 | 08:39 PM
Viper98912's Avatar
It wasn't really an upgrade in terms of performance, it was more for look and matching the front look. The piston bore is the same size, and the rotor is only slightly larger. I felt a very slight difference in the amount of rear squat when braking moderately, but it was very very slight.
Old Feb 6, 2013 | 10:02 AM
That's what i was thinking too...Anyways Good Work Again
