How to identify tire rub
I have a slight rub on the rear passanger side only. Car is on cut H&Rs, 265/30/19, fenders pulled, rolled and a bunch of trimming(brackets are flush), camber correction at -1.75 each side, net offset of -25. Fitment is near perfect, I can barely get my pinky between tire/fender and it looks great. It only hear slight rubbing when I launch hard, not over bumps. Any tricks on identifying where the tire is rubbing? Yes, I did search but found nothing.
TIA, Mike.
Willtheyfit.com helps alot in visualizing where you rub.
Pretty sure if you've on cut H&R springs, you're rubbing the outter fender lip NOT by where the damper is.
I'm on stock H&R's and i have no fender gap so im sure your cut ones are the reasoning being any rubbing you end up finding.
Its just weird cuz I ran them on my c230k with no problem, but on my c55 they rub just on that rear driverside. So bad I wont even let people ride in her at the moment due to how embarrasing it is
you mean leave the tire on and just lower the car with the jack until it hits the tire?
