C55 - moving needle Tachometer at Idle
09 C63 AMG, 05 C55 AMG
At Idle, my C55 needle on the tachometer or RPM gauge, slightly moves.
My friends star computer shows it fluctuates between 625-650. No Codes, No CEL, No misfiring, engine is running smoothly. TB has been cleaned, MAF has been replaced. Same issue still occurs.
Any ideas? The movement of the needle is very slight but my previous c55 and clk55 did not do this.
Any ideas anyone?
Funny, I replaced my voltage regulator this Saturday (finally) and I am a bit underwhelmed by it too. I still have an occasional minor shudder at stoplights.
Worst is it didn't fix my SOS teleaid error that I've had since I bought the car. Tried STAR "not present" trick, looked for trunk splitter, and heard this might work. No dice.
C55 AMG
i've noticed quite a difference by replacing all my breather hoses (4 + adapter) and my engine has never been so smooth! At lights i almost dont even know the car is on. My RPM gauge does not twitch when its idling i believe... but i haven't paid that close attention i guess.
I replaced my breather hoses in an attempt to figure out why my oil keeps getting blown out and leaking everywhere even after fresh seals on the valve covers and breather chambers. So far so good....
My C55 does the same thing, but only at idle - and even then, only infrequently. I'd say I've noticed this for the last several years.
I have often thought maybe some bad gas from time to time (I only run 93 octane premium by the way)? Don't know for sure.
Have not replaced the voltage regulator, but did put a new battery in last year. I don't think that made any difference. My car has low miles on it (37K) so I thought maybe the fact that it is not driven all the time or extensively is another contributor.
It's really so minor that I really don't give it much thought even when I do feel it happen.
car, cl55, flictuates, fluctuates, gauge, idle, idling, mbworld, move, moves, moving, needles, normal, slightly, suspension, tachometer, voltage
