Oil change...
Old Nov 14, 2003 | 10:50 PM
norb's Avatar
2009 C63 AMG
Oil change...
Is there a tube in the back of the block that is for pumping out the oil?
Old Nov 15, 2003 | 05:10 AM
Steve Clark's Avatar
C32AMG
There's a black plug
in what would normally be the dipstick tube.It's what's used to suck the oil out at service time.
Old Nov 17, 2003 | 05:22 PM
auxo's Avatar
03 C32AMG, 05 ML 500, Ducati 998S
There is a drain plug for draining motor oil
Remove the rear under panel (there's two pieces), and you should be able to find a drain plug right where the engine and the transmission meet (in case you are wondering, no it is not transmission oil drain plug, it is for motor oil)
I was assuming that oil was sucked out in these cars until other kind members of this forum pointed it out for me.
I just changed my oil 2 days ago...
Old Nov 17, 2003 | 07:10 PM
rrf's Avatar
rrf
Mercedes sucks, j/k.
They use the black cap towards the rear of the motor, you know where your dipstick SHOULD be....
I like to change mine between services, so far I have drained once and sucked once. Sucking is easier, but I feel better after draining it. I have the lifts and it only tales me 5-10 minutes longer. I am sure that draining takes out more flakes filings and deposits, but MB thinks otherwise so.....
Sucking is an easier 'clean-hands' operation though.
Old Jun 27, 2008 | 10:18 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
does anyone have a pic of the location where to suck the oil out?
I only see the plug on top of the supercharger and the plug above the supercharger near the passenger side.
Old Jun 28, 2008 | 02:02 AM
calimax's Avatar
RENNtech C32 AMG
Originally Posted by rrf
Sucking is easier, but I feel better after draining it. Sucking is an easier 'clean-hands' operation though.
Dude, you left your self wide open on that one, I couldn't resist, lol! J/K!
Old Jun 28, 2008 | 02:16 AM
TemjinX2's Avatar
any one know? do i just take the oil from the fill cap?
the oil vaccum hole on the c350 is near the top of the engine closer to the fire wall. Some say on the c32 its the transmission fluid. can someone confirm where to suck the oil out of?
Old Jun 28, 2008 | 02:42 AM
calimax's Avatar
RENNtech C32 AMG
If I recall correctly, the oil is the round black cap toward the splitter and the tranny one (rectangular?) to the passenger side of the S/C that has the red key in the middle of the cap
Old Jun 30, 2008 | 09:55 AM
edtv82's Avatar
From: dayton ohio hopefully it will be some place warm and sunny when i finish med school
2002 C32 AMG silver & 2003 Lancer Evolution 8 black very moded
this is where you pump the oil out
Old Jun 30, 2008 | 02:17 PM
TemjinX2's Avatar
1+
thats perfect. thats exactly what i needed. thanks
