lowering front of c32?
Old Apr 11, 2015 | 08:57 AM
madspeed's Avatar
2003 c32
Just picked an 03 c32 one owner vehicle with only 55,000 miles. Very happy with it for now. Planning a few upgrades of course. Been looking at the H&R springs, but really dont want to lwer the rear, it sits right where I like it the way it is. What are your thoughts of putting front only springs on to close that larger front fender gap?
Old Apr 11, 2015 | 11:28 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
just do all 4 springs and put thickest spring pads in the rear...
Old Apr 11, 2015 | 01:54 PM
madspeed's Avatar
2003 c32
Are the pads included with the springs? If not, what exactly do I need?
Old Apr 11, 2015 | 11:48 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
springs pads are OEM...
do a quick search and you'll find tons of info on spring pads...
Old Apr 12, 2015 | 11:32 AM
///AMGSC's Avatar
2019 GLE63s
Here's a pic of how it'll sit with H&R springs and a #4 pad in the back. Rear is a little too low for my liking but I used rear adjustable camber and I'm content now.
Old Apr 12, 2015 | 11:34 AM
///AMGSC's Avatar
2019 GLE63s
http://www.ecstuning.com/Mercedes_Be...ngs/ES1752169/ Link for the spring pads
Old Apr 12, 2015 | 01:39 PM
madspeed's Avatar
2003 c32
I stumbled on a thread where others thought the H&R was a bit too low in the rear and they used both a number 4 pad and a number 2 pad, one at the top of the spring and one at the bottom. May look at doing that. My previous car was pretty low and rode like crapola. Was on KW coilovers and still rode like crap. I dont want to sacrifice the nice ride i now have with the oem c32, but really need to close that front gap. Looks like I'll be ordering the springs and some pads.
My old ride...
Old Apr 13, 2015 | 01:26 AM
steverwrx's Avatar
'03 C32, '14 Durango R/T, '10 Touareg TDI
I have Eibachs on mine with the #4 pad in rear. Could not tell the difference in ride and looks great!
Old Apr 13, 2015 | 01:42 PM
ECSTuning's Avatar
Former Vendor of MBWorld
2012 SLS AMG
///AMGSC,
Thank you for sharing our link!
David
Old Apr 13, 2015 | 03:29 PM
raf12690's Avatar
c32 amg
You know I was just going to start a thread on this. I also wondered why the c32 stance is so high in the front and perfect in the rear. Why do the newer c230 sports sit so nice, yet still clear curb stops? (c32 barely clears stock).
Also my right rear tire wears 2x as fast as left rear. Is this do to limited slip or.... I know the C32 has negative camber issues etc.
So in a nutshell...what's the best way to even out the front height AND get a better, more even wear on rear tires????? There's got to be something that they fixed going forward in the c230 sports.
Old Apr 13, 2015 | 03:47 PM
madspeed's Avatar
2003 c32
Its not that the C32 sits higher in the front, it's that the fender opening is much larger than the rear giving it the appearance of it sitting higher. Not sure why they did that....
Old Apr 13, 2015 | 04:08 PM
madspeed's Avatar
2003 c32
@ECSTuning, when installing H&R springs, are new rear lower spring shims required?
Old Apr 13, 2015 | 05:02 PM
madspeed's Avatar
2003 c32
Assuming a fresh alignment is recommended after installing the H&R springs, is there enough adjustment or anything else needed such as a camber kit?
Old Apr 14, 2015 | 08:13 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
I recently purchased a c55 that appears to be lowered in the front only. I believe this is the reason the car has so much oversteer. Be carefull messing with the geometry of the car. It may have unexpected and unwanted results.
Old Apr 14, 2015 | 08:32 AM
madspeed's Avatar
2003 c32
Definitely agree with that, thanks for replying! I'll be ordering H&R springs shortly
Old Apr 14, 2015 | 01:07 PM
ECSTuning's Avatar
2012 SLS AMG
madspeed,
It is recommended that you replace them when changing the springs. We have them available to order on our site and you can get to them by clicking HERE. Let me know if there is anything else I can help you with.
David
Old Apr 14, 2015 | 03:11 PM
///AMGSC's Avatar
2019 GLE63s
David
+1 for ECS tuning, ordered both the springs and pad from them. Quick shipping and love the ride quality
Old Apr 15, 2015 | 01:28 PM
ECSTuning's Avatar
2012 SLS AMG
///AMGSC,
Thank you for your support!
David
