CHECK YOUR FLEX DISKS!!
Old Mar 18, 2016 | 08:30 PM
Naugamanator's Avatar
2005 C55
This public service announcement brought to you from my used car dealer, who told me that he'd replaced both flex disks before I bought the car... and a little drive vibration that I ignored for several weeks.
PLEASE CHECK YOUR FLEX DISKS! They are at the front and rear ends of the drive shaft. If it has *any* cracks in it, it should be replaced. If it looks like this, it must be replaced *immediately*! Failure of this part may cause catastrophic damage to the trans tunnel, mount, trans output shaft, and drive shaft.
Fortunately I caught this one just in time.
Old Mar 20, 2016 | 04:26 PM
Smokey31's Avatar
C55 AMG
Wow that doesn't look like it should of happened.
Old Mar 20, 2016 | 05:20 PM
ItalianJoe1's Avatar
2003 CL 600
That was either installed wrong or there's some other major problem, it looks like it's been compressed longitudinally, possibly from worn trans mounts/engine mounts? Has the car been in an accident? Center support bearing in good shape?
Old Mar 21, 2016 | 06:55 PM
2005 C55
No doubt that the engine and trans mounts were likely worn out for many, many miles prior to being replaced six months ago. I'm the second owner, and the car is at 134,000 miles. There is no evidence that the car has been in an accident.
As I understand it, these are reinforced rubber parts, and can fail on their own over time.
Old Mar 22, 2016 | 02:31 AM
Khan 55's Avatar
2004 CLK55 AMG W209
What was the brand name engraved on these when you removed them? I just bought a new one for me front from the dealership when I could have bought 2 new Meyle ones for the same price as dealership. I haven't gotten down to changing it as yet though.
Old Mar 22, 2016 | 02:39 AM
Khan 55's Avatar
2004 CLK55 AMG W209
I am of the belief that your replacements were not OEM as the OEM one has torx spline bolts and not hex allen key style bolts.
Old Mar 22, 2016 | 10:24 AM
2005 C55
Sorry, did not check the brand after it was replaced. It's very possible that it was the cheap Meyle brand. I replaced it with the near-OEM Lemforder.
Old Mar 22, 2016 | 01:25 PM
sick430's Avatar
CLK Cabrio
I have torn a number of flex discs, it happens, it all depends on how you drive. They are designed to take the punishment away from the drivetrain.
Old Mar 23, 2016 | 03:25 AM
Khan 55's Avatar
2004 CLK55 AMG W209
I agree but my OEM one on the car has lasted 240 odd thousand kilometres and is only showing cracks now.
Old Jul 25, 2016 | 06:22 PM
jvakos's Avatar
E63 SL55 996TT C5Z06
Reviving an older thread on these Flex Disks....
i think my Front and Rear Flex disks need to be replaced as i have some pretty bad vibration when in gear and when in idle my engine vibrates like crazy. i already replaced the motor mounts, trans mount, plugs & wires and nothing has fixed this.
would next logical check be of the flex disks as the culprit?????
what is the correct part number for those?
dealer 6 years ago changed my rear and used part #230410015 but doesnt come up on several MB parts sites as the correct one for C32.
most of the MB parts sites list these parts for Front and Rear so assuming these are the new/correct numbers for front and rear??
2034100215 - REPAIR KIT REAR $83 bux on parts.com
2034100447 - REPAIR KIT FRONT $172 bux on parts.com
Old Jul 25, 2016 | 07:16 PM
2005 C55
I think you mean 2304100115 for the rear
http://www.mbpartsworld.com/p/__/FLE...304100115.html
Unfortunately there are multiple numbers listed as the Front disc, and none for the rear - you'll need to call your stealer and get their opinion on the part numbers.
I seriously doubt that the flex disks are the cause of your current problem though - the vibration from a flex disk only shows up when the driveshaft is spinning. Don't have a guess on your idle vibration...
Old Jul 26, 2016 | 02:25 AM
Khan 55's Avatar
2004 CLK55 AMG W209
As mentioned above, the flex disc only function when the propshaft is spinning, so it could be either engine mounts or you could have a problem with the vibration damper or the flex plate which is spinning as the engine is idling. Maybe inspect the condition of your vibration damper/crank pulley and maybe someone knows how to test the flex plate on the engine however I wonder if this can contribute to engine vibration.
Old Jul 26, 2016 | 06:07 PM
edgar86's Avatar
GLK CDI 320 2009
I need to order 2 piece for my C55 , one in the front and one in the rear ?
Its the same part ?
Sorry iam bit confused with this flex disk
Old Jul 26, 2016 | 11:13 PM
jvakos's Avatar
so the dealer tells me for a C32 the flex disk parts are these:
front flex disk = 2304100115
rear flex disk = 2034100215
i may just replace the rear flex disk since i've driven the car pretty hard and manually shift often at high RPM's which probably wore out my motor mount and trans mount early (got 3 years of of them)
my idle is slightly rough when in park/neutral, so makes me think its the MAF or throttle body? its more noticeable when in Drive for sure.
i just love this car still but at 13 years old and 116k miles these increasing repairs and and mystery on what to fix exactly is making me think its time to pull the trigger on that W212 E63 that i've been eyeing for 3 years now ))))
still lovin the c32
Old Jul 27, 2016 | 05:42 AM
Khan 55's Avatar
2004 CLK55 AMG W209
Its the same part ?
That's true. It is the same both front and rear and share the same part number. Might as well change the bearing and the mounting or carrier while you at it.
Old Jul 27, 2016 | 11:31 AM
Gcarpenter's Avatar
03 C32 amg, 2002 ML320
The C32 does not have an MAF, intake temp and pressure control injectors. The throttle actuators on these cars crap up with burnt oil from blow by, a catch can really help reduce this bulid up. Great $135 investment.
Old Jul 27, 2016 | 11:35 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
They are not the same front to rear. The rear is slightly different and needs to be to fit properly.
Old Jul 27, 2016 | 12:01 PM
jvakos's Avatar
yes, the dealer told me that for a C32 these are the correct flex disk numbers which ARE different for a C32 per the dealrer \
Old Jul 29, 2016 | 03:21 AM
Khan 55's Avatar
2004 CLK55 AMG W209
Didn't know that. Sorry for misleading people
