Front 6-pot calipers from SLK55AMG. Can I use 345mm brakes?
Old Jul 11, 2016 | 11:43 AM
busta55's Avatar
'04 C55 AMG
Exclamation Front 6-pot calipers from SLK55AMG. Can I use 345mm brakes?
Finally bought pair of 6pot front calipers from SLK55. I'm gonna use them on my C55.
Guys, do you know, can I use my original C55 brake discs with these calipers? 345mm
Calipers are regular ones (for 340mm rotors), NOT 030 package.
Old Jul 11, 2016 | 01:34 PM
busta55's Avatar
'04 C55 AMG
no, I'm not. Anymore opinions?
Old Jul 11, 2016 | 03:32 PM
///AMGSC's Avatar
2019 GLE63s
Originally Posted by Plutoe
You are going to screw up you brake system bro!!
So we have to run 6/4 pots to have balanced system? I would mess mine up if I went with 4pots from slk55 in the rear while still keeping stock front setup?
Old Jul 11, 2016 | 03:34 PM
busta55's Avatar
'04 C55 AMG
I have 4pot calipers for the rear also
Question was about front rotors
Old Jul 11, 2016 | 03:42 PM
cm60k's Avatar
You can use 4-pot or 6-pot Fronts & Rears, nothing to do with balanced..!,,
the only thing to consider, is Front Rotor should to be bigger than Rear Rotor for braking mass weight of the Engine..!!
,,ZAYED,,
Old Jul 11, 2016 | 03:45 PM
cm60k's Avatar
Yes sure, you can can use C32/C55 Front Rotors with Slk55 calipers..
,,ZAYED,,
Old Jul 11, 2016 | 03:59 PM
busta55's Avatar
'04 C55 AMG
,,ZAYED,,
Thanks!
So no modifications needed? It doesn't matter that rotors 5mm bigger than slk55 ones?
Old Jul 11, 2016 | 04:23 PM
cm60k's Avatar
As i remember; you only need to put (2mm) washers between hub & caliper bracket, to balanced the caliper in the Rotor center,,
(340x32 VS 345x30)
,,ZAYED,,
Old Jul 11, 2016 | 04:30 PM
busta55's Avatar
'04 C55 AMG
they both 30mm in thickness. 340x30 and 345x30. Only 030 brakes are 360x32
Thanks for the info!
Old Jul 11, 2016 | 04:37 PM
cm60k's Avatar
No bro.,
Slk55 Front Rotor is (340x32)..!
Front 6-pot calipers from SLK55AMG. Can I use 345mm brakes?-slk55-1714210112.jpg
Front 6-pot calipers from SLK55AMG. Can I use 345mm brakes?-john-s-c55-rotor-6-pot-caliper.jpgFront 6-pot calipers from SLK55AMG. Can I use 345mm brakes?-john-s-c55-rotor-6-pot-caliper-1.jpg
Front 6-pot calipers from SLK55AMG. Can I use 345mm brakes?-john-s-c55-rotor-6-pot-caliper-2.jpgFront 6-pot calipers from SLK55AMG. Can I use 345mm brakes?-john-s-c55-rotor-6-pot-caliper-3.jpg
,,ZAYED,,
Old Jul 11, 2016 | 04:46 PM
busta55's Avatar
'04 C55 AMG
My bad
But strange why so many people writing about 340x30: https://mbworld.org/forums/c36-amg-c...ml#post5697543
Old Jul 11, 2016 | 04:52 PM
cm60k's Avatar
Yeah, my wrong typing about the Thickness..
,,ZAYED,,
Old Jul 11, 2016 | 04:58 PM
busta55's Avatar
'04 C55 AMG
Oh, I quoted your own post, lol, didn't notice at first
Old Jul 12, 2016 | 02:35 AM
Khan 55's Avatar
2004 CLK55 AMG W209
Check the CLK forum. I did a post on this. Although I don't think I put photos of the front. None the less as Zayed mentioned, use industrial type washers as I did. I wrote in the post what I used as my disc were shot and new ones locally from agents are insanely priced. Nobody else stocks them two piece in my area so I would have to opt for Ebay which I didn't. Only difference I noticed was heavier steering.
Old Jul 12, 2016 | 05:23 AM
busta55's Avatar
'04 C55 AMG
Thanks folks! But I found already 340x32 discs from SLK55 in great shape, picked them very cheap ) happy happy
Old Jul 12, 2016 | 06:13 AM
cm60k's Avatar
Awesome, do you have pics. of them..?
,,ZAYED,,
Old Jul 12, 2016 | 02:59 PM
///AMGSC's Avatar
2019 GLE63s
Oh okay great, thanks!!
Old Jul 12, 2016 | 05:37 PM
busta55's Avatar
'04 C55 AMG
,,ZAYED,,
Not yet, will post in a week or so when I put them on a car.
Old Jul 13, 2016 | 11:50 AM
WaveyKat's Avatar
Something Slow
you have to use the Rotors from the SLK55 For the 6/4 Setup and also you will have to cut the Dust Shield a bit to fit the Caliper.
Old Jul 13, 2016 | 11:53 AM
busta55's Avatar
'04 C55 AMG
yes, I know that, but thanks
One more question.. Anyone painted calipers with regular car paint? Is it ok or I need only heat-resistant paint? Also what lacquer should I use?
Old Jul 14, 2016 | 04:46 AM
Khan 55's Avatar
2004 CLK55 AMG W209
Regular car paint should work. As long as you apply clear coat thereafter. 2k lacquer is always best for that shine. Dono if you guys call it that over there.
Old Jul 14, 2016 | 07:50 AM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
Probably 1.2k lacquer knowing us crazy non-metric types.
Old Jul 15, 2016 | 08:44 AM
busta55's Avatar
'04 C55 AMG
Changed my mind on painting calipers, because my car is silver and I don't think yellow or orange calipers will suit my car. Just done a touch up to mask scuffs, I'll leave original color Not like new of course, but I think on a car it will be OK
Old Jul 15, 2016 | 09:18 AM
cm60k's Avatar
Looks NICE,, i think you will use 2-piece Rotors isn't..??
,,ZAYED,,
Old Jul 15, 2016 | 04:31 PM
busta55's Avatar
'04 C55 AMG
Thanks!
Yes, got them with calipers can't wait to put them on the car
