C55 Electrical Problem
Old Jul 29, 2016 | 07:40 PM
crazeazn's Avatar
C55
Hey yall! Need your help.
A month ago while driving, the cars electronics stopped working while I was driving (all gauges turned off, hvac non responsive, no turn signals, cant open windows/sunroof) which I attributed to the battery being old. I went to the dealership that day and purchased a new MB battery and plugged it in.
Fast forward, car is still having this problem. I will be driving for about 10 minutes then the same thing happens OR if the car has been off or sitting outside for a few hours and I crank the car on, none of the electronics work. I will recrank a few times then sometimes everything works again. ESP disabled will come up and a check engine will come on. After I shut the car off, ESP disabled and the check engine lights go away.
The only other problem I've had was that my dvd navigation stopped working all of a sudden as well (around the same time). It wouldn't read my disc, so I ejected the disc and it wouldnt auto load, and I accidently jammed it back in bc I'm an idiot.
Based on forum searching, some common problems are the voltage regulator and the radio. Any other ideas? I want to know what I'm getting into before I go. Time to ditch and get a corolla?
Old Jul 30, 2016 | 09:34 AM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
It may also be an issue with rear SAM. It controls a lot of electronics that you are reporting as malfunctioning. Was the car in a heavy rain recently or even some low level flooding situation?
Old Jul 30, 2016 | 12:59 PM
crazeazn's Avatar
C55
It was not, car is garaged and elevated.
Old Jul 30, 2016 | 01:16 PM
blacksage's Avatar
2006 C55
When you say fast forward, how long has it been? My car was having the same issue and it was the battery, It would always start strong after sitting, but restarting it after a decent drive was a struggle. I would have to turn it off and crank it again to get the electronics to work.
Maybe something is killing the battery?
Old Jul 30, 2016 | 02:53 PM
crazeazn's Avatar
C55
about 2 months. I've had to study for the bar and didnt need to really use the car in that time frame.
Old Jul 30, 2016 | 03:44 PM
Lenin's Avatar
You can monitor your voltage by following steps below.
1. Insert key into ignition, switch to position “1“.
2. Press the appropriate buttons until the mileage is displayed within the Multifunction display.
3. Press cluster illumination button (1) 3 times in short succession. The display should be showing the battery voltage now.
Monitor the voltage before the start, during the start and after the start. And of course when the electronics fail to function (if it will still be displaying the voltage). Let us know the results.
Old Jul 30, 2016 | 06:32 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Check ground cables?
Old Jul 30, 2016 | 07:48 PM
crazeazn's Avatar
C55
which is the cluster illumination button?
Old Jul 30, 2016 | 09:15 PM
Lenin's Avatar
Follow the instructions in this document: https://mbworld.org/forums/attachmen...ator-guide.pdf
Old Jul 31, 2016 | 11:24 AM
crazeazn's Avatar
C55
13.4~13.5V under load.
Drove it quite a bit last night, no errors or issues thus far.
50~70mph highway runs, lights, a/c 3/4 speed, radio on.
I also change the keyfob batteries as well.
Old Jul 31, 2016 | 11:44 AM
Lenin's Avatar
Let's hope it's a fluke. Otherwise, if voltage is fine and it happens again, check the ground like Viper said. Let's hope it I is not your rear SAM.
Old Aug 1, 2016 | 12:10 AM
crazeazn's Avatar
C55
Drove it all day, no problems. Its around 100 degrees, so drove it around all day with a/c full blast.
Then, on the way home like 10 minutes ago, the a/c went out. Not all of the electronics like last time. hahahaah. this car makes me giggle.
