Project: Rescue the Cdirty2
Well, I'm back at it- buying neglected money pit AMG's that desperately need attention. I just can't help myself, haha. I recently picked up a 2002 C32, while cosmetically in great shape, it has been ignored mechanically for a while.
When I first got it, it had no power, SC not engaging at all. It had a code for a knock sensor, so my friend and I pulled the SC to replace it and guess what we found? An abandoned mouse house with a nicely chewed through knock sensor harness. (This is where we came up with the name "Cdirty2" haha.
We repaired the harness and threw in a new sensor for good measure and VOILA! I had a super charger and power for days. Still some other issues to deal with, but it was better.
Following that, I also changed plugs, and replaced a half dead coil pack, replaced the tires, fuel filter/fuel pressure regulator.
The paint on the wheels had gone to crap from brake dust and improper use of cleaning chemicals, so when I changed the tires, I did a quick rattle can respray.
I'm still fighting a rough idle issue. Some times it's subtle, sometimes it feels like the car is misfiring badly and I have to pick up the revs a little at a stop light. It FEELS like a misfire, but it's not. This feeling is only at idle, not while driving. No related codes (only codes are for the cats, but that's because they're not there) plugs are new (old ones looked a little lean), wires swapped out with known good ones, coils are all good. The fuel filter DID make an improvement. Idle smoothed out by about 70% and the butt dyno did notice an improvement in power and delivery. It's still not entirely right though. It no longer feels like it's misfiring at idle, but it's still an issue for sure. Vacuum lines have been checked and replaced where needed, throttle body cleaned, supercharger and plenum gaskets replaced. Just looking for ideas if anyone else has dealt with this. There are a lot of threads out there on the subject, but most lack a conclusion.
Anyway, I thought I'd post here to kind of keep a log of what I've done to the car and what I will be doing. I would also appreciate any insight to my idle issue. Thank guys, good to be back in a Benz.
I repaired my ambient or outside room temperature sensor and after a few days back to negative reading on the cluster. Maybe I ought to replace it with a new one. Sorry to jack thread but my query is relating to your wire repair on the knock sensor. It seems to me if you replace it with the wire of same amount of copper strands it should all be cherry not so?
The C36 was great. I kind of regret getting rid of it, but the C32 makes up for it, lol
When we first fixed ths knock sensor, I would get a cyl 6 misfire anytime I got on it hard. The issue mysteriously went away on its own. Tonight I had a good chance to inspect things under the hood while it was idling in gear. I heard a random popping sound coming from the intake/supercharger that's coincided with the hiccups of the engine. Pulled the air boxes off and took a look at the throttle body and sure enough, air was being pushed OUT the throttle body....
Anyone have some spare updated cams laying around?
I've got a set of original camshafts from an 02 C32 Engine with 98k miles on them. I had them replaced with Kleeman cams. Let me know if you're interested.
How do you like the new cams? Worth the money?
The stock cams were working fine. It all depends what you want to do with the car and how much money you want to spend on it. New cams at the dealership is $1740.00 a piece. I think $600 for a used pair is fair.
Let me know.
Let me know.
Carlsson 2/5's 18x8.5 et35 and 18x10 et30!
They're not perfect, but I only paid $350 for the set. Considering that they're worth about $1200, I really can't complain.
So basically, I still need some camshafts.
Keep us posted on your progress!
Im getting power to the fuse and the relay is functioning properly, but no power to the pumps.
Did a little research and found a handy little list of everything that the individual SAM modules control in the car. Turns out that nearly all of the things that either don't work, or are intermittent on the car, all run through the rear SAM.
So this is good news and bad. It sucks that I need a new SAM, but this could actually fix 90% of my issues with this car.
