What do you have done to your exhaust?
Old Nov 5, 2017 | 12:01 PM
PJmak's Avatar
The previous owner of my c55 removed the resonator and I have to say the car sounds fuken proper when warmed up. Kinda loud for just having that done. He said he had it done at some race shop so not sure exactly what they did. The receipt shows close to $300 from what I remember.
My friend said it sounds like a hot rod. Of course followed with "whats under the hood" question coz he had no clue.
If only I could get rid of the whining sound that almost all c55s have.
I'll try to get some videos at some point, in the mean time feel free to share your setup, pics, and sound clips...
Old Nov 7, 2017 | 08:55 PM
RenC55AMG's Avatar
2005 C55 AMG
I had my resonator and secondary cats removed, great sound and tolerable drone at highway speeds. The whining at idle is your power steering pump and normal.
Old Dec 3, 2017 | 11:53 AM
K-Hill's Avatar
'06 C55 AMG
Other than sound, what does removing the resonator and secondary cats do for the car? Any MPG gains? I have a C55 I just bought about a month ago and am trying to learn all I can.
Thanks in advance.
Old Dec 3, 2017 | 03:37 PM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
Thanks in advance.
Doubtful it does anything but add an old school muscle car sound to a Benz. That's all I've ever noticed. MPGs actually suffer due to the sound forcing the go-pedal to the floor.
Old Dec 3, 2017 | 09:03 PM
Ackime Snow's Avatar
C55 AMG
I have headers, no primary’s, no secondaries, and no resonator. Sounds pretty mean.
Old Dec 3, 2017 | 11:12 PM
Fantomas's Avatar
2006 ML350, 2005 C55, 2004 E55
It's actually the engine oil pump. Both the E55 and C55 have dual pickups, front and rear, that's the reason for the dual oil pan bolts. The whining noise is made by the gear mechanism for the dual oil pickups. Both the E55 and the C55 have this design. The S55 has a single oil pickup and does not have a whining noise at startup.
Once I find a decent exhaust shop in Portland my plan is to eliminate the resonator and the secondary cats, insert an X pipe and run true duals to the mufflers. Seems to be good for about 320-330rwhp with tune. Down the line I plan on getting some Eurocharged shorty headers and high flow primary cats. Reason I want to do this in stages is to keep the volume under control and revert if there's too much drone.
Old Dec 4, 2017 | 12:11 AM
PJmak's Avatar
Any fix for the fuelpump whine?
Old Dec 4, 2017 | 07:18 AM
EezyBake's Avatar
2005 e55 amg, 2003 c32 amg, 1998 acura integra gsr k swap, 2000 honda s2000, 2008 honda cbr 1000rr
Gutted my muffler strategically, not just randomly hacking away at the engineering that went into it. But **** that one can was way more work then when I gutted my old w211 e55 ones. It's off now though bc I'm replacing piping w 3in stainless I got left over from my track whip...so debating if should put modded muffler back on as well. Or go dual tips too
Old Dec 6, 2017 | 01:07 PM
ghiaguy's Avatar
C55 AMG, 300D-T & Karmann Ghia
I've been running my C55 with the resonator and secondaries removed for about four years and have always planned to go with an X-pipe and true duals. Let me know what you find when you add this, im curious if the sound changes, etc... Always wanted to say it has true duals
Old Dec 7, 2017 | 12:43 PM
feets's Avatar
2006 C55
I plan on some exhaust mods but I want to keep the factory tips. The car needs to be quiet inside while cruising but sound like a proper V8 when stoked.
Old Dec 7, 2017 | 06:00 PM
amgen's Avatar
C55 AMG T with Kleemann K2 and some stuff: 414 hp and 562 Nm :-)
feets, that´s what I have: Kleemann headers without primaries and stock all the way back inclusive secondaries. Tune on that of course.
Mean rumble at startup and after that almost like stock at idle. Startups turn heads.
Highway cruising no extra drone.
But when you push it, it roars nice! That´s the way AMG should have done from factory in my opinion.
Inside the cabin the difference isn´t too big but it´s there. You have to be outside to hear the big difference stock/tuned, now the V8 really
rumbles when pushing it just a tad, cruising round town. "-No doubt that´s a V8 in that car!!"
Old Dec 7, 2017 | 06:26 PM
PJmak's Avatar
Heres a very short clip of mine. Resonator removed only.
Old Dec 14, 2017 | 01:14 AM
swedepat's Avatar
2011 C63 AMG, 589hp
I took it off and set it in storage
Made a new one.
Longtube headers with merge collectors followed by 100cell cats.
Then complete new all the way.
Routed it into a single 3" pipe all the way from behind gearbox to reardiff.
Then split it into dual 2.5"
One 3" silencer
And two 2.5" silencers.
Sounding like a v8 should sound like.
No blurbing like two fourcylinders that only fires on three..
Rgds
Old Dec 14, 2017 | 02:51 AM
daynger's Avatar
C55 AMG
Whine will be the idler pully, mine was.
Cheap easy fix.
Mine also sounds alot like yours, full stock system with just the secondary cats cut out, i didnt want it loud so didnt do the resonator delete.
Old Jan 2, 2018 | 06:17 PM
gofisch's Avatar
2005 C55 AMG
EC headers, secondary cats and resonator removed.
https://mbworld.org/forums/c32-amg-c...ound-clip.html
