Fan shroud for alternator removal
Old Jul 7, 2019 | 09:16 PM
Shribe's Avatar
C55
Greetings, I have had no luck with voltage regulator replacement so unfortunately the alternator needs to come out. I have removed serpentine belt, coolant hoses, removed connections to alternator and bolts, have it pried loose, have the fan unbolted and out, but can't get the fan shroud out for the last bit of clearance. Any advice would be appreciated. Thanks!
Old Jul 11, 2019 | 08:22 PM
Handbuilt's Avatar
C55 AMG
might be a late reply but there are plastic clips that hold the fan shroud to the crash bar.
Old Jul 11, 2019 | 09:07 PM
Shribe's Avatar
C55
Thanks for the response, I did finally figure out how the clips work (only two on sides and push the top) and got the shroud out and got the alternator out. Alternator is tested and ready to go. Time to put the whole menagerie back together.
Old Jul 11, 2019 | 09:43 PM
Handbuilt's Avatar
C55 AMG
Great Shribe! I remember when i had to do an alternator swap on my C55. I ended up pulling my whole rad and support off to do it. Hated that but it was so worth it!
Old Jul 12, 2019 | 06:18 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
In the future you can lossen the motor mount lift the engine and get it out from there too.
Old Jul 12, 2019 | 10:52 PM
Shribe's Avatar
C55
Will I need to clear my visit workshop code or will it be clear from having battery unhooked and the alternator now working? Also just add that beautiful blue coolant through the pressure tank (50/50 distilled water) and it will draw itself full? Next time I hope it is just the voltage regulator but if the alternator goes I think I will stick to the process I know all too well. Are motor mounts difficult in general?
Old Jul 13, 2019 | 10:45 AM
insame1's Avatar
Replacing the mounts is not very easy. Just undoing one of the bolts and lifting the engine is easier than having to deal with the radiator and coolant imho.
Old Jul 19, 2019 | 03:42 PM
Shribe's Avatar
C55
Just as a follow up to my questions to help someone who finds this post, fill through the expansion tank on left side all the way to the black plastic which is full. Just taking hoses off required almost 2 gallons to fill. Warning light cleared on its own.
