Dyno set up question
Old Jul 21, 2004 | 03:16 PM
flymd90's Avatar
2003 C32 AMG, 2001 SLK 320 Designo Copper
I am taking my 03 C32 to a Dyno shop for testing and am unsure of what I need to do to set the car up for this. Can anyone out there help me? (a self admitted FNG)
Old Jul 21, 2004 | 03:31 PM
hantzis's Avatar
2004 C32 AMG
No preparation is required. The dyno shop should do everything (including removing engine cowling if present).
A few things to keep in mind:
1. Turn AC OFF. Don't just turn the air flow knob to 0, push the AC button to off (if you don't, it will give you slightly lower results)
2. Turn off traction control (ESP?)
BTW - if you have 93 Octane in your area, you can change a setting in the computer management system (maybe dyno shop has the hardware/software) to 93 octane instead of Base 91. It would be GREAT if you can do before and after runs on each setting to see the power difference. If you only have 91 octane in your area, obviously don't switch to 93.
DynoJet dynamometers are the standard these days in measuring power. The main reason is from one shop to the next (diff elevation, etc), these dynos produce very consistent results. As opposed to inertia dynos like dyno dynamics where user input error usually produces inconsistent data and poor accuracy.
If you are using a dynojet, check out my site, http://dynoperformance.com to compare your results to other vehicle dyno results...
Good luck and MAKE SURE to post the results
Old Jul 21, 2004 | 03:40 PM
AaronC's Avatar
C32
I dont beleive that my car has that button. Would it help to turn the temperature to a hotter setting before setting the airflow to 0?
Old Jul 21, 2004 | 03:54 PM
hantzis's Avatar
2004 C32 AMG
hmmm. strange. I know the 2002 C32 is a bit different with temp control. See if there is any way to turn AC off in the manual. If not, then I would tune the temp controls so heat is coming out, not AC.
Old Jul 21, 2004 | 04:51 PM
cschow's Avatar
2006 Corvette Coupe
You can shut off the AC compressor by toggling the EC button until the led lights up. EC = economy mode = A/C compressor off.
You should probably also engage the dyno mode.
Old Jul 21, 2004 | 06:06 PM
flymd90's Avatar
How do I engage the "Dyno" mode in a 03 model?
Old Jul 21, 2004 | 06:13 PM
flymd90's Avatar
That's great info! I really appreciate it.
The place I found (through a Google search) uses a Mustang(?) Dynamometer model MD-AWD-500-SE. I have no idea if this is an inertia dyno or not. Anybody know of a good place in the DFW area to get this done? The place I found is in McKinney, Tx.
Old Jul 21, 2004 | 07:25 PM
BenzoAMGpower's Avatar
Cars and boats!
you cant completely disable ESP by a click of a button... does anybody know how to put hte car in Dyno mode (this mode shuts off traction control or ESP completely)?? Theres a series of steps and sequence of buttons to press to do this!!
Old Jul 21, 2004 | 07:40 PM
Nimbus's Avatar
Alot of cars
I like to know this as well. Someone with the correct info please chime in.
Old Jul 22, 2004 | 12:08 AM
Steve Clark's Avatar
C32AMG
https://mbworld.org/forums/showthrea...ight=dyno+mode
Old Jul 22, 2004 | 09:51 AM
flymd90's Avatar
Thanks, Steve. That's great info!
Old Jul 22, 2004 | 10:12 AM
Cars and boats!
spank you, spank you very much :v
