Flex Disk
Old May 14, 2020 | 04:17 PM
Lephoko's Avatar
C55 AMG
Flex Disk
Good day all,
I would like to find out if the Front and Rear Flex Disk are identical? Can a part number for Front Flex disk fit in the Rear Flex Disk position?
Thanks and regards,
Albert Lephoko
Old May 15, 2020 | 12:16 PM
cm60k's Avatar
Yeah,
Front & Rear have differ part #, but they are identical, and interchangeable to each other..
-;-ZAYED-;-
Old May 15, 2020 | 02:22 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
Originally Posted by Plutoe
Go to any dealer to answer that question!!
Do you ever offer up any help at all? If you don't know - why waste your time and anyone else that look to the forums for help? The dealer is going to ask for the VIN, go to EPC, see two different part numbers. Their answer? - yep, different parts. cm60k took the time to help. You should shut your trap.
Old May 16, 2020 | 12:49 PM
kaixdiego's Avatar
190E, C36, C55, CLK55, ML55
Was this in reference to C55 or C32? Are both interchangeable Zayed? Interested to know.
Old May 16, 2020 | 01:17 PM
Lephoko's Avatar
C55 AMG
C55 AMG, Thanks
Old May 16, 2020 | 01:26 PM
cm60k's Avatar
No bro., C32 & C55 have differ flex discs..!,
F&R "C32" flex discs comes with (6) holes, while "C55" flex discs comes with (8) holes F&R,
both comes with (110mm) dia., but differ holes numbers & differ holes pattern,
*C32 flex disc #: "203 410 02 15" & "230 410 01 15", both are interchangeable,,
*C55 flex disc #: "129 410 01 15" & "203 410 08 15", both are interchangeable..
-;-ZAYED-;-
Old May 16, 2020 | 10:37 PM
kaixdiego's Avatar
Haha yes I knew both were different between c32 and c55 but meant are each respectively interchangeable.
Thank you Zayed, I posted a while back tracing down confusion over rear flex disc numbers for c55, this is great info to know front and rear can be swapped as what’s marketed as fronts are easy to be found but harder to find those matching rear part numbers.
https://mbworld.org/forums/c32-amg-c...4110215-a.html
203 411 02 15 is for the “rear” flex disc alone, 203 410 08 15 is for the kit including new hardware.
