Insane oil Burning!!
Rob
- Rear main seal
- Valve covers
- The little cover on top of one of the valve covers
- Oil filter canister
I would check those first as they are more likely than the piston rings. Some of these may only be slightly leaking, or may be leaking like crazy
OP, do you notice blue smoke in your exhaust? At a rate of 2 qts a day I'm pretty sure you'd have a substantial amount of blue smoke in your exhaust.
If you're not leaving oil everywhere you drive and park and no blue smoke, maybe you have a bad oil level sensor. Unfortunately our cars don't have dipsticks. If it were me, I'd drain the oil and measure how much you actually have in there. You could be way overfilled right now because a bad oil level sensor keeps telling you to add oil even though the oil level was right. Being far overfilled can cause it's own set of problems and cost you alot more money than you've already spent.
Thread from the W211 platform, but oil level sensor technology is basically the same and can cause the problem you have:
https://mbworld.org/forums/e-class-w...refueling.html
There were definite leaks at the oil cooler, valve covers, and rear main seal, but never enough to leave a spot in the driveway. Fixed all but the rear main seal. No change in consumption.
I changed the oil level sensor on my last car, thinking that must be it. Nope.
No amount of valve stem sealer, thicker oil, or additives seem to help. I haven't had a chance to borescope the cylinders or do a compression test, but the car runs great otherwise...
As far as I'm concerned, it's just a fact of life with some of them. I wish it wasn't, but I'm 2 for 2 now. I just drive it and keep a couple of quarts in the trunk for every time the warning comes on. You're not alone. I love the car otherwise and will drop another motor in it when this one either gets too bad or grenades.
No way in hell you are loosing that much oil from there and you should definetly not be driving that car if that much oil is coming out.
Cracked oil pan could be an issue. I just dont know how youd not see the leak with that much oil coming out.
.I can't find the bulletin referencing the intake tract seals I mentioned earlier, but here's a vid talking about it. The video shows changing the seals on the intake for an M112 V6, but the idea is the same for M113's. M113's have two seals as I stated prior, unless you have an E430 which only has one seal like the M112.
https://www.youtube.com/watch?v=y4Uv0xQgU2k
As I stated in my initial reply, being overfilled can cause a host of big and costly problems and suggested checking his actual oil levels...but we haven't heard back from the OP yet about further symptoms, issues, or resolution.
Afterwards I noticed 4-5% better fuel economy and a slightly better throttelresponse. But honestly the weather has stopped me more accurately exploring the improvements.
The new 2 plastic rings seem to be made of a slightly different material and had both several grooves on the outside for a tighter fit in comparison to the old ones.
I don´t regret changing them!
Thank you "bauhaus313" for this excellent tip!! :-)
Btw, I haven´t had any oilconsumption problems with my C55.
Might be a good time for a 55k swap. Prices on used 55k engines are more expensive then before Covid19, but they are still fairly reasonable.
That would be my plan of attack.
of maryland. My C55 has been holding up like crazy. Had my mechanic check her out and he confirmed its the valve seals. Currently considering one of two options but I need your help! Motor Runs like a champ but honestly want more power/fun with this car. Plan A, Is M113k Swap and make around 650 HP with all the mods. Plan B, is one you guys are going to hate me for… but I was thinking AWD K24 Turbo in the C55 Haha. I can fully build the motor for under 10k and have a 900+ Whp Turbo C55. Thinking about Minting out my Interior too. Anyone with Clean set of Ash Interior Interested in selling?
