Stage one is like 2.XXX then stage two is 5.xxxx stage 2 does it include stage one in that price or it's 7.xxx $ alltogether?
And what times does stage 1 or 2 runs 1/4 and like 0-60?
Selling my ML55 and thinking about 2003/4 C32 and those upgrades!
i believe Stage I is about pulleys / ecu mainly. it includes:
Stage I:
7" Crankshaft overdrive pulley
- Aluminum water pump pulley
- Aluminum alternator pulley
- Aluminum power steering pulley
- Two (2) belt tensioners w/ belt
- Windshield washer reservoir w/ hose fitting
and on 91 pump gets a claimed (and customer-verified) 400hp 400lb/ft and runs 3psi higher than stock.
Stage II is Stage I plus headers plus ignition and intake upgrades (however features Stage II instead of Stage I ECU tuning)
Stage II:
- evolution 1 Power Package
- Stainless Steel Performance Headers
- Denso Iridium Plugs (set of 12)
- evosport 8mm plug wires
- SL55 intake splitter and hose
- Powerchip/evosport custom-tuned evolution 2 software
the ignition plus the headers and install takes longer, which explains the higher price.
i believe people claim about high 12's to low 13's in the Stage I, and haven't heard much from Stage II times.
Stage I:
Stage II:
Quote:
Stage I:
Stage II:
Originally Posted by 99e36m3
i believe Stage I is about pulleys / ecu mainly. it includes:Stage I:
Stage II:
OK but does price of stage 2 includes stage 1?
yes it is stage I plus extras. stage I just means pulleys and ECU. stage II means the same pulleys + more agressive ECU. so yes essentially it includes stage I but is revised ECU and adds some extra stuff. several people have run Stage II without the headers, so the price would be cheaper.
must save money!!!!!!!!!!
stage one is pretty tempting once the warranty gone out.
So i pay 5 thousand smth and get my 430 hp with 420 ft of trq right?
Coz it's kinda confusing
yes, that's correct.Originally Posted by BoBcanada
So i pay 5 thousand smth and get my 430 hp with 420 ft of trq right? Coz it's kinda confusing
it's some what expensive, but consider the outcome IMO it's worth it if you want to run w/ the big boy and own them. i.e. the e39 M5, w210 E55, even Ferrari 360 modena like cars.
Originally Posted by FrankW
yes, that's correct.it's some what expensive, but consider the outcome IMO it's worth it if you want to run w/ the big boy and own them. i.e. the e39 M5, w210 E55, even Ferrari 360 modena like cars.
I defenetly want, and will
ExploreSuper Member
i think the complete stage II was about $7000 fully installed. i don't want to misrepresent EVOsport, so check with them, though i remember this being about right. it's nearly $5,xxx for the actual parts, but install is more. so when you say $5k for 430hp that is uninstalled i hope you know. but evosport has a great customer support on this board and lots of happy customers so i would check them out as i hear their stage II rocks
I believe you are right, 99me36m3. Stage II installed is going to run $7k mostly due to the headers ($1999 for the header itself + 6hrs labor). Gains from the header alone is about 15-20whp.
Modding a C32 will put the carinto another league. Seriously guys, I have done some mods and now my C32 is a completey different beast.
There are few cars that will blow you away that are in the same price range. category.
BV
BV
A-Men, brother. Modded C32 will run with the big boys. If you lose a race (which is rare), you won't lose by much.
View a modded C32 as a "better M5" at about 1/2 the price.
BV
Originally Posted by bverotti
Modding a C32 will put the carinto another league. Seriously guys, I have done some mods and now my C32 is a completey different beast. There are few cars that will blow you away that are in the same price range. category.
BV
I can agree with the statements! Originally Posted by Vomit
A-Men, brother. Modded C32 will run with the big boys. If you lose a race (which is rare), you won't lose by much. View a modded C32 as a "better M5" at about 1/2 the price.
Wiedermann
It won't be 5K, remember you are in Canada, don't forget taxes and the exchange rate.
The parts list was correct except I did not get a belt...I have stage I plus the SL55 splitter when all was said and done total bill in Canadian dollars was just shy of $6K which includes installation. Saving up for stage 2 now.
I would say 430 HP and the torque figure is the best case scenario with stage II, there are many factors that will affect the final HP/TQ
I have dynoed my car and it made 320-325HP/~317 TQ at the wheels about ~385HP/~370 TQ at the crank, don't get me wrong I love the kit changes the car completely. I am expecting about 20 more horses and the same in TQ at the crank with stage 2
My best 1/4 mile is a 13.1 with the kit but consistent 13.3 for sure, prior to the kit my best was 13.2 with consistent 13.6. So I picked a solid 3 tenths and about 2 MPH with the kit. I think I can break into the 12's with some new tires as mine are close to bald now.
0-60 I would peg at probably 4.7 depending on traction, putting all that power down without slicks is sometimes hard.
T
