K&N air filters for C55
Old Dec 1, 2004 | 12:39 AM
G8R GRAD's Avatar
Are they available yet? Where can I get them?
Old Dec 1, 2004 | 10:02 AM
BenzoAMGpower's Avatar
Cars and boats!
same ones as the 03 and up CLK55!!!
Old Dec 1, 2004 | 11:02 AM
05C55's Avatar
Gain is usually marginal and they do not filter as well as the OEM elements. It may change the intake exhaust note a bit though. I wouldn't be against trying them out. You need two right?
Old Dec 1, 2004 | 11:17 AM
Cars and boats!
you need two of them!!!! The improved airflow should help to lean out the air/fuel mixture a little bit at higher RPMs where it is needed!!!
Old Dec 2, 2004 | 12:54 AM
G8R GRAD's Avatar
Benzo,
Are you sure they are the same as the ones used in the CLK55 '03 and newer?
I called K&N last month directly and they said they haven't made one yet for the 2005 C55.
Old Dec 2, 2004 | 02:03 AM
BlackC230Coupe's Avatar
Former Vendor of MBWorld
Fast Cars!
Originally Posted by G8R GRAD
Benzo,
Givin the engine and airbox are identical to the CLk55 it has to fit. K&N probably just didn't get their hands on a C55 to see for their self.
Old Dec 4, 2004 | 03:18 AM
G8R GRAD's Avatar
K&N air filters
Benzo and Black C230,
While I thank you for your input. You are both incorrect. Based on your fairly convincing responses, I ordered the same size air filters for the CLK 55. They arrived and I attempted to install them. They are not the same size. The C55 filters are actually much narrower. I guess I should have listened to K&N when I called them directly and they said they havent made the correct filter yet for the C55.
Old Dec 4, 2004 | 03:34 AM
Fast Cars!
WOW! thats strange. I dont see how its possible though. The engine and airbox seem to be identical. How is the box labeled? does it say for 03 and up CLK55? i am just wondering if they sent you filters for the W208 CLK55 instead of W209 ones?
If it is W209, well then i still can not get over how its different. Sorry about that. I am sure K&N will take them back and refund you.
Old Dec 4, 2004 | 11:29 AM
Cars and boats!
they probably sent you filters for a W208 CLK55!!!!
