E55 AMG's Blower.. How much bigger then C32's?
55s are close to 2.2-2.4L. They will not fit directly onto C32. One will need to redesign the kompressor drive, intercooler and intake surge tanks. At this point one might as well get an Opcon or Whipple kompressor and make it work.
BTW, Eaton has nothing to do with IHI, and "crank force" has nothing to do with engine size.
What's the max PSI the C32 engine can take?
more air and lower psi are not mutually exclusive. bigger screws do move more air and they does not always = more psi
point still stands... there is NO point in changing the blower on the C32. if 500 hp is not enough... well go buy a supra or a skyline.
http://members.aol.com/profchm/boyle.html
Volume is fixed therefore pressure is directly related to air mass and its pressure. We can also assume that there is no radical change in operating temp also.
PV = nRT holds true. As does any other gas law.
Your parents would have done better to have spent the money on an education and not a car.
No knowledge is a bliss.
Little knowledge is a burden.
May the "crank force" be with you, to help you with your burden.
Even Eaton states as much as I did and that is good enough for me.
Did you mom write this!!!!!!!!!!!!!!!!
This like, Budda!!!
Dude!!!!!!!!!!!!!
I like!!!!!!!!!!!!!! In particular my "witty self endorsement" and my "indifferent stance".
Look, Miroj. It is quite obvious you have no IDEA what you are talking about. So please lay off "crank force".
Spare all of us of your lack of knowledge and your
Between us?????
Dude, sorry - but whatever you are sniffing I do not want any part of it.
May the "crank force" be with you.
Oh, wait - I get it - CRANK, Oh I am sorry, now it make sense. Just do not burn down the house.
Just dont light a match ........
You seem to know a lot about dumping your nitro on people, I guess anyone who believes you deserves you as a supplier.
This like, Budda!!!
Dude!!!!!!!!!!!!!
Appreciate the reply's and
at your comments to miro.
Note the the flow vs the pressure ratios. Also note the power required vs pressure/volume between the two.
this is all fun and games until someone gets hurt, namely your ego.
You also fail to indicate whether the differences in air-flow represent significant gains in the engine over the OEM variety (justifies the cost) or where the pressure is taken ..... plenum or output chamber ? Before or after IC.
Its no wonder you feel the need to believe everything you read. Is there really such a thing as a gain for no cost ? Or is it just more of the Vadim majic we have come to enjoy and love.
EDIT: Unlike Eaton, the POWER CONSUMED to crank the SC is not stated.
You are a genius, in which field I have no idea.
