Wheel size on a C43
1998 C43
Wheel size on a C43
HI all:
I was just wondering how large of a wheel size I can go without modifying the car (roll fenders, etc etc.) I do not plan on lowering my car just yet, but I might upgrade the suspension in the future.
I was thinking about running 19x8-8.5. Will it fit w/o problems?
DLS
DLS
2004 E320
Damn I thought that AMG already rolled the fenders stock and someone could put 8.5 in front and 9.5 in rear no prob? (I could be wrong) I would just watch the offset of the rims and you should be fine with 8.5!!!
1998 C43
I am not too sure about AMG already rolling the fenders for you. I think that I will run 18x8 or 8.5's instead of the 19's. I am planning on lowering my car and think the 18 setup seems better for what I want. Gotta save up the money first!
DLS
DLS
1996 C36 AMG, 1995 Volvo 850 Turbowagon
my friend has a c280, with amg rims 7.5x17 up front shod with dunlop 8000 225-45-17 (not lowered), he said full lock turns caused rubbing
1998 C43
Hey thats really cool. If that is the case, then I will definitely reevaluate the wheel set up I will roll on. How wide can I run on an 18 inch wheel with a lowering of about 1.5 inches?
DLS
DLS
2004 E320
4 sure you could go 18x8.5 front 18x9 rear but you could still prob go 18x9.5 in back with the right offset!!! Anyone know the exact OFFSET needed to go (8.5 front - 9.5 rear)???
E55,Tundra,Z4MC,X5
Wheel sizes
If you have an AMG C-class, you can run up to 8.5 on the front and 10 on the back. That is the setup I run and it works great. Now I did have to modify the rear just a little but not much. Due to the rolled fenders from the factory (AMG), you don't have to worry that much about rubbing as long as you have the right offset. The offset I am using on both front and rear is 30mm. The stock AMG wheels (if memory serves me right) are a 38mm offset. For 8.5 to 9.5" wheels, I would suggest using a 32mm offset...... Hope this helps......
2004 E320
Thanks A Lot Wesss! Do you have any pics plz!!! I would love to C your ride. Are you able to still make a U-Turn without rubbing on the inside fender??? If not then that's definately the OFFSET to use!!!
E55,Tundra,Z4MC,X5
No prob. I'll have to take some additional pics of my car. My hard drive crashed some time ago and I lost all pictures. I think there should be some pics of my car floating around this site somewhere or at least in the archives. Look for a black C43 w/ AMG SL 2 piece wheels.
I have no problems whatsoever making U-Turns. No rubbing.
Is anybody going to the eurocar show on Sunday 11th at California Speedway (Fontana). I think I will be there!!!
