Anyone know about tuning the C36 AMG?
The AMG exhaust is already as free flowing as you can get. All you're likely to accomplish is a reduction in power and an increase in noise. I replaced the cats on my C36 with high flow aftermarket ones. The performance suffered greatly until I pitched them in the garbage where they belong. The AMG exhaust is a quality, accurately engineered piece of equipment. If any aftermarket ****** who builds the same exact exhaust for a myriad of vehicles tells you the stock AMG system can be improved upon, ask for proof. You likely won't get any.
https://mbworld.org/forums/sl-class-r129/130194-chip-any-good.html
Another site with ECU Modifications is:
http://www.revzone.net/products_ecu.htm
These are simple modifiactions which will free some decent power. Worth a look.
Good Luck!
The only problems with the K&N filters and the MAF's going bad is not caused because of the filter. If you buy a new filter and pop it in, you'll be fine. The MAF only goes bad when you recharge/clean your filter and apply too much oil. If you over oil your filter, it will clog up the MAF and it will cause it to go bad. K&N filters are great, just know what you're doing if you plan to clean and re-oil it.
OR
http://www.revzone.net/products_ecu.htm#Benz
http://www.greenfilterusa.com/vehicl...0Benz&make=C36
These performance upgrades should be more than enough for any C36...
Enjoy
