Steering Dampener
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Steering Dampener
just for everyone's 411: Replaced the steering dampener the other day. It's a ten minute job. You'll need to jack up car, on both sides, and two 16mm wrenches - one ratchet and one box-end will suffice. The steering dampener itself can be compressed by hand, and it costs $23 dollars through www.autohausaz.com
did it make the steering tighter/heavier? I think mine might be due...
It tightened it up, I've been driving around town mostly as of late, I'm sure the difference will be greater once on the highway.
Originally Posted by MBHustla858
you'd imagine such a "performance" car would have a rack in there, but whatev
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
Originally Posted by c55m8o
neither did the previous gen M5 of the same era... ![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
1996 C36 AMG, 1995 Volvo 850 Turbowagon
c43
WOuld it not work because there is no room? I figured getting rid of the box would free up room... and if its in the 210 why would it not work in the 202? Shouldn't it be plug and play? Lastly how would you get two shocks to work in the place of one? Cheers.
~ Ashkan
~ Ashkan
hey guys i have a clk430, and was wondering if there is a way to get a stiffer or heavier dampener. and if so do you think this would give the car better steering response.
thanks
and happy new years everyone!
thanks
~ Ashkan
~ Ashkan
2014 ML350 4Matic
The W210 E-Class (including the E55) is rack and pinion. The rack is bolted the the rear of the front subframe.
The W208 CLK is based on the W202, therefore like the W202 it has recirculating ball steering. The steering box is attached to the left side longitudinal frame member.
It would be an extremely difficult project to fit the W210 rack to the W202. The W202 does not have the subframe that the W210 has.
While a lot of W210 stuff is common to the W202 (and other M-B also), the rack is not one of them.
