suspension rattling!
Old Sep 20, 2006 | 08:00 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
hey guys,
whenever i drive over rough road surfaces, a nasty rattle happens from the front of the car. sounds like its coming from the suspension ... im 99.99% sure that its not from something like an altoids tin rattling away in the glove box. ive had this problem with my old car, as did a friend of mine with her BMW.
anyone have any input as to what this may be? bushings? i have warranty, but wanted some idea b4 taking it into the dealership.
thanks!
m
Old Sep 21, 2006 | 03:51 AM
e320newbie's Avatar
91' 300e // 99 300e TD // 00' ML55 AMG
i feel this too
Old Sep 21, 2006 | 09:35 AM
NitrogenBalance's Avatar
none
Get it to a garage and put it on a lift. That would be my first move. You will most likely find the problem. If something is loose you should be able to find it.
Old Sep 21, 2006 | 05:41 PM
MBHustla858's Avatar
ur gonna have to put it up in the air and try to localize the sound, it could be a broken sway bar bracket. the rear links like to fail often too, but ur saying its from the front.... good luck
Old Sep 24, 2006 | 02:40 AM
linuxfoo's Avatar
get your car up in the air and check the lower control arm bushings, check for cracks and tears in the stock rubber bushings.
Old Sep 24, 2006 | 01:28 PM
e320newbie's Avatar
smart fellas! service this week, ill add it to my check list for the techs
Old Oct 7, 2006 | 10:56 PM
im planning on taking my car into service this week, under warranty. if i do, i'll let you all know what the problems were/are.
Old Oct 7, 2006 | 11:35 PM
Kar don's Avatar
Mercedes-Benz
def a sway bar link.
Old Oct 9, 2006 | 04:29 AM
e320newbie's Avatar
nice ill tell them the car rides fine i just hear the rattle but ill get em to peep the sway bars ! thanks again!
Old Oct 9, 2006 | 09:00 AM
OzC36's Avatar
Silver 1996 C36
Maybe...
Lower control arm bushings
Tie rods - Requires new drag link assembly
Steering Damper
At least that is what MB told me and my steering/suspension seems perfectly fine and doesn't even rattle!
Old Nov 29, 2006 | 02:39 AM
ok, guys. had my car fixed at the dealership. according to them, here were the problems (like with OzC36):
(1) tie rod ends
(2) lower control arm bushings
thank you, starmark!
