Cruise control problem
Old Jun 9, 2007 | 06:27 AM
Broke Driver's Avatar
'99 C43K AMG
Hi guys,
My cruise control suddenly decided not to work, I was trying to look for a fuse for it, but didn't have any luck with that.
Any ideas?
-Joseph..
Old Jun 10, 2007 | 06:08 PM
FLYNAVY's Avatar
BMW and Mercedes
Originally Posted by Broke Driver
Hi guys,
Any ideas?
-Joseph..
1st troubleshooting question: Did you just change any of the tires on your car?
Old Jun 10, 2007 | 07:52 PM
'99 C43K AMG
Yes.. One tire of mine blew out on the freeway a week ago, and the spare is on there right now, but the cruise control has worked since the spare has been on, so unless there is a delay factor, it doesn't seem to be the problem.
But then, i do not oppose to trying anything to get it to work..
Old Jun 11, 2007 | 01:27 AM
FLYNAVY's Avatar
BMW and Mercedes
for some reason or another it took my car a few days to register the fact that I had replaced the rear tires and not the fronts (ran over a bolt and decided to replace both). Even still, CC will initiate for a couple of seconds before it fails. I was skeptical, but the MB tech even said that the small difference between rolling diameter between new tires and old ones is enough to trip off the sensor. So I would start there first, and if that doesn't correct things then start looking at fuses. I can't speak specifically for the C43, but on other MB's (and most other cars) I have had, normally a faulty fuse will have an effect on other things too.....so unless you have had concurrent troubles with something else, I would be surprised if that was the problem. Hope that helps.....at least a place to start
Old Jun 11, 2007 | 11:21 AM
Howellja's Avatar
CLK, R350
Its probably your tire, I had the same issue when i had a flat and had to drive home on my spare mounted with a directional snow tire.
Old Jun 11, 2007 | 12:28 PM
'99 C43K AMG
I had a quick look at my fuse boxes, and there doesn't seem to be a particular fuse that directly controls the cruise control, perhaps i'll let it ride out for a few days and see what happens.
Old Jun 11, 2007 | 02:43 PM
juicee63's Avatar
2011 twin turboed prius
Did you install sprint booster?
Old Jun 11, 2007 | 03:49 PM
'99 C43K AMG
No...
That would make a difference?
Old Jun 11, 2007 | 05:40 PM
juicee63's Avatar
No...
I think it is what may have effected my Cruise control.Tires sound like a definate culprit
Old Nov 24, 2018 | 04:11 AM
ryan83's Avatar
04 CLK500 & 10 GLK350 (Past: 83 380SL, 03 C230 Coupe, 2013 C250 Sedan, 97 C280)
I'm a broke grad student with a 97 C280 and the cruise control doesn't work between 65 and 95 mph. All tires are used, so different brands and different tread patterns, but all are same correct size. So, I have to spend nearly half the value of the car on a new set of tires to fix this issue?
I did read elsewhere that the 3rd brake light bulb being bad might have been the issue and I did manage to fix the fixture with some soldering and a new bulb.
Also, if I manage to incrementally go up with the cruise cotrol stock from 65 to about 67 it will take untill the road gets a little bumpy and then it fails again. But no amount of bumps will disrupt the cruise control if I'm going -65 or 95+.
Old Nov 24, 2018 | 04:40 AM
DRBC43AMG's Avatar
Have you checked the brake switch just behind the brake pedal? If I recall correctly (it was several years ago...) the BAS alarm light was on and I think the CC did not engage. It was a faulty brake switch which caused the problem. Changed it (not expensive) and all the problems disappeared.
On the other hand, if you say your 4 wheels have 4 different tyres and in different states of wear, that could also be the cause of the problem
PS Your post is on the C36/C43 AMG page. You could find more replies if you post on the generic W202 page: https://mbworld.org/forums/c-class-w202-27/
Old Nov 24, 2018 | 05:06 AM
ryan83's Avatar
Thank you @DRBC43AMG
Do you mean brake light switch? If so, it's a sub $15 dollar part so I'm happy to give it a shot but I don't have any of the symptoms listed here http://www.mercedesmedic.com/how-to-brake-light-stop-switch-benz/
PS: I'm sorry I didn't know there was a separate thread for AMG 202s. Thanks for letting me know.
Old Nov 24, 2018 | 08:26 AM
DRBC43AMG's Avatar
No probs. Good luck!
