C43 Trans Blew
Silver 1999 C43, 1990 Jeep Grand Wagoneer, 2002 Honda Insight
C43 Trans Blew
My 99 C43 is making grinding noises in first gear. I just dropped it off for a professional diagnosis. I live in Carlsbad, CA and wondered if any of you have experience with transmission repair shops (including Hoehn MB) in the north San Diego county area? Thanks in advance for your input.
09 335i 03 CLK55 AMG
Well I'm in NY so I can't help you. Hope for the best though with your transmission. Looking at your cars its funny we both drive a honda insight and a C43 what are the odds of that?
Dealer will give you a crazy bill for you tranny or anything! I think it's better that you find a good independent shop to do the repair. I've heard dealers will charge you ALOT for a new tranny for AMG c-class.
One thing I hate about SD is that most shops will rape you as well. In LA there is alot of competition so shops will do a good job at a good price. I hated leaving my car overnight for a brake job in SD. In LA I get my car back in 2 hrs. Good luck
Yeah, at this point, find a place and have it towed there. Don't mess with the "I think I can make it" thought process. You're basically driving your bill up hundreds of dollars per mile. Good luck with everything.
You may want to call Sun Valley Mercedes Dismantlers. They've been rebuilding Mercedes-Benz transmissions there since forever. That's a long flatbed from Carlsbad, you may want to rent a truck and take it yourself.
Actually with this transmission, by the first sign of something mechanical it's too late. The failure is usually the needle bearings, and once they start to break up there's enough metal in the works so that you don't want anybody trying to put it back together.
Trans blew.
Thank you all for your suggestions. Right now I am awaiting a precise diagnosis from Charlie's Foreign Car Service. I have dealt with him for many years and know him to be honest and fair. I'll let you all know how it comes out. I really appreciate this forum and your input.
yeah thats what my mechanic said too the needle bearing broke and took everything with it so and he also said that this problem is very common on the E430's and clk 430's
hey guys,
what is this "grinding sound" that some of you speak of with the gearboxes? ive been hearing some slight noise for years now, i am assuming that it is just the gearsets moving around. do i need to be worried?
(she has 76,000 miles total, with trans oil and filter changed at 60,000 and 75,000).
hey guys,
Early, first production 722.6 transmissions used a bushing, which supports and lubricates the planetary gears; the noise you hear( if coming from the trans.) is planetary failure.
99 C43 AMG
i replaced my trans at around 60k miles, i did the labor myself, paid under 3 grand for hte new trans and control module w/ the latest programming for hte newest valve body. that was shop cost and i paid that much since it came w/ a unlimited mileage/ 3 year warrenty, good luck
i was considering a used trans, but what would i do that when ALL mercedes 98-99 have bad trannies in them...... i figured i'd do it once and do it right.
noises are hard to diagnose, a mechanics stethoscope will lead you in the right direction. A Transmission planetary gear noise will change pitch as the transmission shifts thru its gears, and no noise in 4th gear with a 1.1 ratio, assuming no major planetary failure.
What type of noise do you hear, my C32 made a high pitch wine on start up in the morning and change pitch with engine RPMs, it was the power steering pump.
722.6 valve bodies have gone thru several design changes for increased driverablity and durability thru its evolution, starting in 1995. Last count was Five.
For durability, when buying a rebuilt transmission make sure you have the latest design valve body, and the transmission control module must also be flashed with the proper soft ware to support the valve bodies’ hard ware.
Greatkatuna My 99 C43 is making grinding noises in first gear. I just dropped it off for a professional diagnosis. I live in Carlsbad, CA and wondered if any of you have experience with transmission repair shops (including Hoehn MB) in the north San Diego county area? Thanks in advance for your input.
95 Audi urS6 Quattro
its not a whine. in fact, i wonder if its coming from the engine (valves), but the sound is "similar" to the sound a jeep cj manual tranny makes, definitely NOT as loud though. it also sounds "similar" to a diesel engines "clack clack clack". again, NOT as loud. i always thought that it sounded like the gearsets moving around. and its semi-sporadic. ive had the car in to the mechanic for various tranny work (trans flush, new shift plate), and they never red flagged the noise ... it's been happening for years now.
man, i dont know if its the alignment of the planets or something, but ive been ocd'ing about my tranny like a madman lately! in fact, i havent been even driving it that much lately bc of that!
if ur tranny hasn't been done yet, it will need to be done. its just a time bomb
If the tranny issues are ultimately related to a needle bearing, or set of them, and failure is just a matter of mileage, has there been any thought to the economics of changing those bearings, or, in essence, rebuilding the tranny before the needle bearings let go and mess up the rest of the works?
Have you asked your tech to diagnose that specific noise, if it were transmission relayed you would have been walking home long ago. For those intermittent problems I ask the customer if I can drive the car, for a couple of days. Good luck.
