Best Performance Mods for the C43?
Old Sep 22, 2007 | 09:06 PM
C43bob's Avatar
1998 C43
Suggestions? Appreciated.
Old Sep 22, 2007 | 09:38 PM
MBHustla858's Avatar
there isn't anything you can really do, best bang for the buck is probrably doing a 55 swap
Old Sep 22, 2007 | 09:45 PM
rlee02135's Avatar
2004 C32 ///AMG
HPS Gen1 blower.
Old Sep 22, 2007 | 11:51 PM
AMGJared's Avatar
09 335i 03 CLK55 AMG
Depends on how much your willing to spend.
Old Sep 23, 2007 | 05:47 AM
taxi driver's Avatar
A190 500E C43 CLK430
Exclamation
# 1 first do the 55 gearbox upgrade just to be sure, then you can go on
chip,sports filter, sports cat. the obvious 55 motor , 55 kompressor.....
It's your wallet, how deep can you dig ?
I have the # 1 already done , next step time will tell ,, Roger
Old Sep 23, 2007 | 06:04 AM
E55 PWR's Avatar
e55
AMS Performance Crank pulley, Evo-sport pulleys, headers & custom exhaust system. Anything else... won't do much.
Old Sep 23, 2007 | 11:46 AM
DarthCY's Avatar
98 C43, 86 Porsche 951, 98 Volvo S70 T5M
The 55 gearbox upgrade is a new one to me. What does that entail exactly. As in is there a writeup or part numbers? Thanks.
Old Sep 23, 2007 | 03:54 PM
E55 PWR's Avatar
e55
gearboxes are same part number 722.6, I don't see how that would do anything at all.
It would be MUCH easer to just swap to a 5speed than to go to another auto b/c auto ECUs are meant to work specifically with certain engine ECUs so trying to mix and match is usually not possible.
Old Sep 24, 2007 | 03:57 PM
speedybenz's Avatar
AMG C43, 1999
Build a ram air system by installing two air ducts into the spots where the fog lights are now then run 3" piping up to the stock airbox. Much better thottle response.
In the process clean up the inside of your stock airbox and remove most of the air deflectors in the box and remove the stock screen that is located at the airbox outlet.
Make the ram air tube so that they will spilt into two pieces within the engine bay and that way if it is raining really hard you will not pull any water into the motor.
Jeff
Old Sep 24, 2007 | 05:08 PM
Ghostrider's Avatar
01 CLK 430
High flow exhaust manifolds might be a good choice as well. I got +10 whp and +10 rtq...
Check out the ***208 Prototype*** thread in the W208 forum.
