* Weight Reduction thread *
Took out a decent amount of stuff from my car today and weighed them on my super accurate scale in order to get an accurate weight reduction amount. Thought I'd share the results with you.
- CD changer w/ mount & carpet cover = 7.170 lbs
- plastic spare tire circle cup = 1.275 lbs
- Jack = 3.430 lbs
- Tools = 1.625 lbs
- Rear Spare Tire = 49.8 lbs
total weight reduction for today = 63.30 lbs exactly.
Not a bad days work, and since every 10lbs ~ 1HP thats not too bad. I am still far off my goal of 250 lbs + but I don't think it should be too difficult to get there. my OEM battery has been replaced with an interstate aftermarket battery (not a lightweight one but a similar replacement model) and even those are usually 10lbs lighter than OEM, so the car is probably already a little bit lighter, but I am going to go all out and get the Odyssey PC680 w/ battery box.
The only thing I want to do in order to get that is disable my parking lights that stay on when you lock the car (for about 10 seconds). anyone know how to disable that pointless feature?
Anyways... lots more weight savings to come
you bought the wrong car if your trying to make it light- you're basically going to take away what sets it apart from the competition in a good way without making large enough gains to beat the competition at that game...
i'm by no means adverse to weight savings and have engineered my modifications to be as light as possible for what i've done, but i don't really get it.
I could just say that for every AMG sticker you add, you gain 1HP.
you are an idiot
see my above post for my opinion on how cool it is to remove 250 lbs worth or weight from your C43- but if you are unable to comprehend the idea that reducing weight increases performance (in a way that directly relates to what would happen if you increased hp) i don't know what to tell you.
hahahaha, OBD2 scanner has officially been owned.
I appreciate the input though.
I don't know what weight reduction #s can be made without sacrificing anything "real", but i do know that it would be a mistake to do so.
anyways- since that one is debatable, what are you going to remove next? you will quickly hit a wall where anything further removed becomes significant.
It does not serve a purpose if you have AAA plus, I get free flat bed for 100 miles if I ever needed it, I haven't run spare tire in 8 years, its the first thing that always goes. Gotta love AAA
Our brake systems are REDICULOUSLY heavy (out of the SL600 for the 96 & 97 ones) I heard the brake system alone you can save a good 40lbs. I won't be doing that just b/c its too much work IMO and I think stock brakes with less weight + pads & SS lines and the right tires is more than enough stopping power
The stock battery is absurdly heavy as well and you can also drop a decent amount of weight by upgrading the exhaust system.
I will do a full update as I take more stuff out and carefully document he weight for all you guys to learn from.
More to come...
i agree light wheels will help so I am looking to see what alternatives there are. thx for the advice
if you take weight off the front as well it will balance itself out. Either way I don't need 50/50 weight distribution, this isn't a race car, nor is it an E36 M3. If you are worried about stuff like that sell your C36 and go get an E36 M3.
I've already done the E36 M3 route so I wanted a change of pace so I got a C36 which is basically more an old school euro muscle car instead of a cult racer.
E36 M3 = surgeons scalpal
C36 AMG = Massive sledgehammer
2 cents
2 cents
and that makes my car a supersledgehammer?
either way- you are sort of arguing against yourself with that post... talking about how it isn't meant to be a "scalpal" or an E36 when you are the one thinking that weight reduction is so necessary. the returns from weight reduction fall off quick once you're already up to speed... where these cars shine vs. the E36 (mostly due to transmissions/gearing)
