TVT Design, Project C43
Former Vendor of MBWorld
1 Post
Chrysler Crossfire
Well we've just acquired our C43 from Dave this morning and are ready to dig into it and get some good number.
We'll be trying for some dyno numbers this week for a baseline and then go to the ECU tuning from there.
Our goal is to get it to 350 Crank HP. Yes it is very optimistic, but we will be doing it in stages. First shoot for 320 HP with tuning, then 335 HP with bolt ons, and finally our goal with some more radical mods.
Stay tuned for the results.
1 Post
Chrysler Crossfire
We hit the dyno today to get a baseline. 239 RWHP/224 RWTQ
On the dyno graph it shows peak power at 4600 RPM, because of an error inputting the final drive ratio. So the graph shows 215 RWHP, but if you use the formula (TQ*RPM)/5252= HP, you get 239.
Car has KN filters, all else is stock. There is deffinately room for some tuning on the ignition side, but the AFR looks pretty spot on.
Graphs attached.
Graphs attached.
sounds like airplane
sounds about right- what brand dyno? this is a cool project, wish it had more application to my car (so i could spend some $ with you...).
1 Post
Chrysler Crossfire
I figure the DT loss to be at about 23% (dyno owner said 25%). That would put crank HP at 310 HP which I'm attributing to the KN and x-pipe. That puts TQ at the crank at 290. Lower then stock, but a dyno is just a tool.
Basically the numbers are just there for a reference point. I'm pretty sure that when we dyno it again we're going to leave everything the same (wrong rear diff) so as not have to add in formulas and skew results.
Our first round of mods will be tuning and ignition as I see that as the biggest reason for the valleys in the TQ graph.
Another dyno to follow soon.
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
It's a dynapack dyno.
Just calculate the drive train loss as a percentage of the published crank number against the baseline pull.
Dynapack is a load dyno on which you will read 25% - 30% power train loss from the published crank power.
If you were doing your pulls on an inertia dyno your readings would be 15%-18% higher.
Load dyno is best way to go as the RWP is close to what you'll put down on the road.
1 Post
Chrysler Crossfire
So I figured it was time for an update.
These are some pics of the stock engine, airbox, and surrounding items.
The fins in the airbox seem to be beneficial, but in reality they really aren't much more then an obstruction. The fins are pre-air filter and any straightening of the air is disturbed once the air passes through the filter. We've done this on the non-AMG cars and have seen good results.
There are an additional set of fins right before the MAF opening which I assumed were directing air as well, but after taking a closer look they are an inch long and just straight.
1 Post
Chrysler Crossfire
Another thing we removed was the screen Pre-MAF. The MAF has two screens already, this third screen is again a restriction. The only time this might be necessary is if you running without air filters, which I don't recommend.
Here are some after pics.
1 Post
Chrysler Crossfire
Here's the second screen on the MAF and then the MAF with it removed.
We also removed the fins on the elbow leading into the TB. The fins direct the air over the Oil hose and right into the dead center of the TB blade, not an ideal location. With our installation of the catch can, the vaccuum being pulled over the oil hose will not need to be as important as the entire system will be pulling from one source and not three seperate sources.
With the above mods, we've picked up 6-8 RWHP on the 3.2L v6, I'd expect 10-12 RWHP on this model and about the same for the C55/E55 (N/A).
1 Post
Chrysler Crossfire
And finally the disection of the engine.
We're going to be cleaning up the intake manifold and mildly ported the top end runners. This is basically the last time it will need to be cleaned, with the catch can installed very little oil makes it in here.
I also attached a pic of the dirty EGR tube. You can remove this with no ill effects but a CEL.
Also you can see where a little critter had set up camp in the cylinder bank.
2003 Mercedes S500 Lorinser
anthony any new for the injcetors.
also can we get the same work done as on the c43 here to my sclass.
im thinking i got the same crap going on underneath the manifold,
1 Post
Chrysler Crossfire
Ball park price is probably 175-200 range depending on what the fittings cost. The catch can alone is 100.00.
1 Post
Chrysler Crossfire
Today we upgraded the ignition. Now Dave had told me the plugs were relatively new, but Bosch plugs are not ideal for performance. However, I wasn't going to put 16 plugs in based just on that. I pulled the plugs and noticed that the plugs in the rear of the engine were caked in oil and as you got closer to the front they were cleaner, but still looked fouled.
I felt that justified a change over to the NGK Iridium IXs and while we were at it added the Magnecor KV85 wires. With the manifold clean and catch can going in the plugs should not have oil getting all over them and thus last much longer.
We're going to finish up with porting the top part of the intake runners and get another dyno on Thursday to see where this work has taken us.
1 Post
Chrysler Crossfire
We moved onto step 2 of our manifold work today. The top is cleaned and the runners are in the final stage of porting/polishing.
We will also be upgrading the injectors a tiny but larger, but with better atomization. This should improve the TQ curve. The stock green injectors are about 26 lbs/hr, not insignificant for the engine, but the technology of them is quite dated. You can see the difference in the two injectors in the pic below.
not 26lbs. They are the same ones used in the 5.5L motor. They should be plenty fine for Dave's motor.
If I'm right even the Kleeman S/C kit allows u to use the stck inj. However,the AMG 4.3L motor and 5.5l motors use the same inj stck.
none
Looks great anthony, have you seen any of the pics I posted with my intake mani port&polish? What are you using for the job? It should eat up a few days of shop labor...mine has been open for almost 1.5 years..
Also, what technology makes these injectors better? Something to do with spray pattern?? Don't know a ton about injectors so aside from the lbs. I don't know what makes a good injector
My 2cents would be to throw some gasket matched phelonics on there since you've got the manifold out.
