Tire Question .
Old Apr 2, 2009 | 09:10 PM
trinitony's Avatar
E55 C43 993C2S
Tire Question .
For you guys running 18s - what r your tire specs front and rear?
Thanks.......
Old Apr 2, 2009 | 10:12 PM
AMGC's Avatar
Mosselman 190E 16V+ C63S+ Abarth 595
225s front 255s rear slammed like a underage ***** in brooklyn
Old Apr 2, 2009 | 10:16 PM
trinitony's Avatar
E55 C43 993C2S
kool...but 225/? 255/?
Old Apr 2, 2009 | 10:18 PM
denice25's Avatar
civic
mine is 225 front and rear!!!
Old Apr 4, 2009 | 08:06 AM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Is that because you are driving a Civic ?
Old Apr 4, 2009 | 01:13 PM
Z06EATER's Avatar
1997 C36AMG
lol!! mine is 225 all around too!
Old Apr 4, 2009 | 02:08 PM
C43AMG's Avatar
Veteran: Army
Oh no , not you too !
Old Apr 4, 2009 | 03:53 PM
trinitony's Avatar
E55 C43 993C2S
lol...this is wat I decided on - 225/40 and 255/35....
Will 245's fit upfront?
Old Apr 4, 2009 | 04:44 PM
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
Probably not.
You want to have the same front to back outer diameter ratio as a 225/45/17 and 245/40/17 or your cruise control may stop working. You should be able to find a tire calculator on google. I used to use the one at Miata.net, but I'm not sure if it is still there.
Old Apr 4, 2009 | 05:34 PM
trinitony's Avatar
E55 C43 993C2S
Originally Posted by ECTurboGSX
Probably not.
ok...don't think I'll be using cruise with this car though. Tomorrow I'll take the 245s 18 off the E and see if the fit...just because I've them available..lol...However I will be sticking with the 225s..
Here's pics with the car lowered on 18s now...
Old Apr 4, 2009 | 05:40 PM
C43AMG's Avatar
Veteran: Army
Your car looks great , just a little too low in the back.How about so clear corners upfront ?
Old Apr 4, 2009 | 07:04 PM
trinitony's Avatar
E55 C43 993C2S
^ I'll give it a couple weeks and then decide whether to lower the front or raise the rear.
Clear corners, - which vendor/site to buy them from?
Old Apr 4, 2009 | 07:07 PM
C43AMG's Avatar
Veteran: Army
I ordered my clear corners off ebay , and had zero problems with either set (C43 & C230k). IMHO - pick the back end up a bit.
Old Apr 4, 2009 | 07:21 PM
trinitony's Avatar
E55 C43 993C2S
kewl..tks...let me see how in #1 looks in the front first. If it's slammed, then I'll raise the back.
Old Apr 4, 2009 | 07:27 PM
trinitony's Avatar
E55 C43 993C2S
Now I've to figure this one out... Guess a cover will have to do, or maybe a red fox.
Old Apr 4, 2009 | 10:26 PM
ECTurboGSX's Avatar
I had claw marks covering the rear spoiler on my Eclipse, I guess it made a good spot to lay out. I'd definitely try to find a way to stop that if I were you.
Old Apr 6, 2009 | 10:25 AM
trinitony's Avatar
E55 C43 993C2S
Fixed it for now with a car cover. My pcar cover works nicely.....
Old Apr 7, 2009 | 04:10 AM
Mercedes22's Avatar
S500 LWB ( W221 ) - CL63 Biturbo ( W216 ) CL 55 Kompressor ( W215 Sold ) C43 AMG ( W202 Sold )
225/40/18 F + 255/35/18 R
Old Apr 7, 2009 | 11:14 AM
AMGC's Avatar
ya wont wanna run 245s up front. i wish i went with 215s instead of 225s
Old Apr 7, 2009 | 02:20 PM
svt ricco's Avatar
1999 C43 AMG
will 215's be a stretched set up?
Old Apr 7, 2009 | 04:32 PM
tristantiojanco's Avatar
1998 c43
i used 225/40/18 in the front with #1 spring pad n i used 235/40/18 in the rear with 12mm spacer coz my rims are not a staggared set up..it rides fine with eiback springs on stock shocks i put a total of 4 frown ups in the car no rubs or scraping at all...
