C43 AMG Brake/Rotors/Discs
I am now definitely in need of some front discs and will be ordering these http://www.carparts-direct.co.uk/Ros...scs_Detail.cfm
I have decided to go for a full set at £239 for the front (316mm)
and £259 for the rear but the listing shows the rears to be 278mm but I have measured the rears on mine and they seem to be 290mm which is a C36 size?
have I made a mistake or is their listing wrong? My car is a C43 1998?
any help would be much appreciated.
As far as I know, there is no other disc avaiable except the original one.
I am using the R129 discs (SL 55/60 AMG). The size is the same, but the offset is different. You need to adapt...
but when looking at them you understand why, Unique L and R hand
aluminum center and really positive ventilating fan design . They are
also relatively light for it's dimention .
Also if you go the OEM way there is no need to rebuild the front at all ,
just new discs and pads , remember they were E55 equipment and sure
enough capable to stop our C43's Roger
( picture show also 300mm rear discs )
@C43AMG
Do you have detailed information about these 'Italia's discs'?
The disc company at the start of my thread after a couple of weeks of trial and error...... ...................................has finally told me they can not supply the fronts for a C43 (credit to them as they really did try)
These guys say that they expect to have fronts in by July http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
I will try to brake less for the moment, although I have never had a disc crack on me.
I will take ten pairs at this price ,lol
.http://cgi.ebay.co.uk/MERCEDES-C-Cla...3A1%7C294%3A50
http://www.c-klasse-forum.de/wbb3/in...&threadID=9279
For front discs I used an alluminim disc with 1,5mm. Rear discs fits without modification, You only need some more space for tires, because offset will be reduced.
Bye,
Stephan
"yes the disc italia are a perfect fit for you C43 no modification is necessary just bolt them on"
Part Information For X444.902 / Disc Italia Rotor |Vented | Outside Dia: 334mm | Lugs: 5 = OEM: 2104211812, 2104211912
give us a call if we can help,
john
Toll Free 866-272-5396
www.brakeworld.com
Just rolled over 100K a while ago and I'm sure the rotors are on their last legs.
Does someone know the manufacturer of the Italia Discs?
I would like to order some but I am not sure if the are confirm with the German Tüv. Obviously Italia Disc is not manufacturer but importer of European and especially Italian Brake parts. But I wonder why those parts are not available on the European market.
@C43AMG
Do you have any certification with your Italias? I wonder why the rotors on your photo are slottet but Italia disc is drilled or drilled&slotted only?
Are there any other news available concerning C43 rotors/pads?
Bye & happy new year,
Stephan
fronts are from a C230k sport package straight out of the box from any outlet. (not sided)
rears are from an r129 SL (cross drilled option).
Been on the car for 5000k, great brakes
