C43 A/C Compressor Replacement, Help?
Subscribe
Jun 2, 2009 | 04:42 PM
Does anybody have a guide on replacing the A/C Compressor/Dryer on a C43. My mechanic wants 1700 and I can buy the parts for 300.
Reply 0
Jun 3, 2009 | 04:42 AM
The actual replacement of the A/C compressor is easy.
Is the old compressor leaking or has in failed internally? If it failed internally then take it somewhere where they will flush the system fully otherwise your new compressor will live a short life.
If it was just leaking then it will be easy to replace.
1) Release all the gas in the system
2) Drive the car up onto ramps/jack car up
3) Remove the drive belt
4) Remove both A/C lines to the compressor (from the top, remove washer bottle for better access)
5) Unbolt the compressor from below (3 or 4 bolts on the side of it)
6) Remove the compressor out the bottom
7) Install new compressor with new seals on the A/C lines.
8) Refit drivebelt
9) Drive to you local A/C service center to replace the drier and charge the system.
Reply 0
Jun 28, 2009 | 09:10 AM
The parts came in and everything went according to your guidance (except it took me an hour to figure out how to release the belt tensioner)
Everything works great and my total bill was $386.41 instead of $1700
Reply 0
Jun 30, 2009 | 07:23 AM
Did you purchase the receiver/dryer or did the shop recharging the system?
Reply 0
Aug 22, 2009 | 03:15 AM
do u need to replace the a/c collection tank? was told i needed to do it as the compressor is gone, water/vapor may have gotten into the tank...
woops, i guess it's the same question as above
Reply 0
Aug 22, 2009 | 08:15 AM
I only replaced the dryer.
It came with the compressor kit which included the oil. Months later everything is still working perfectly
Reply 0
Aug 22, 2009 | 02:47 PM
my compressor is out too.. could u put up a link to where u got it from? thx!!
Reply 0
Aug 26, 2009 | 05:58 PM
Compressor Kit
BlendAir
Irving, TX
972-313-2025
Reply 0
Explore
Subscribe
Currently Active Users (1)
