Staggering
Old Dec 24, 2009 | 06:35 PM
CatButt's Avatar
C43
Staggering
So, besides the obvious wider tire...what is the purpose of staggering the wheels? I need to get rid of my 19s for something lighter. I was looking at a set of 18s a MBW member is selling but they are either 8 or 8.5. I was considering these with a spacer in rear to get the wheel out there a little. I want to lower the car at least 1.5 inches maybe more with a Cup Kit or coil overs.
Opinions please.
Old Dec 24, 2009 | 08:22 PM
PJmak's Avatar
First, the car looks hundred times better with staggered wheels. All super cars have staggered setup id say.
Car handles a lot better with staggered wheels and has more grip due to wider tires in the rear, especially if you have RWD(which you do)
Old Dec 24, 2009 | 08:38 PM
CatButt's Avatar
C43
I get that part...at least the traction due to wider tire...but on my current set up 225/35/19 245/35/19 versus the setup I am looking at 225/40/18 235/40/18 with a spacer in the rear to get the tread centers outward...I mean we are only talking 1 cm difference. Can 1 cm really make that big of a difference on these cars? I could see it on a track car, like my Miata (which is VERY touchy about unsprung weight). These cars are not Super cars and are not pushing huge HP numbers.
Old Dec 25, 2009 | 03:03 AM
Z06EATER's Avatar
1997 C36AMG
get 255 in the rear a 9.5 in should b gud
Old Dec 25, 2009 | 03:53 AM
BenzMaster19's Avatar
C36 AMG
Just stick with the staggered set-up, it looks soo much better and definitly helps for traction when your making awesome torque.
And yes they are not "super cars" but they are DEFINITLY not cars to take to easily either... and what are you comparing the AMG's too anyways?? AMG's work off of Torque numbers BTW,, the HP numbers are secondary here.....
Old Dec 25, 2009 | 11:15 AM
v0ac's Avatar
C43 AMG & E55 AMG
Depends on your drop really...
I would suggest keep with stock 225front & 245rear
I went 235 front & 255 rear
but my drop is big and it rubs in the back on every little bump on the streets..not fun, next tires i go back to 245 lol
Old Dec 25, 2009 | 11:29 AM
KJI3jflarryfe93's Avatar
what does staggered wheels mean?
please explain it to me.
I am not good with english terms for cars
thanx
Old Dec 25, 2009 | 01:43 PM
PJmak's Avatar
Means the rear wheel is wider than the front wheel
Heres my staggered setup
Im runing 265/30/18 inthe rear on my car and im not rubbing. Fronts im runin 225/40/18
Old Dec 25, 2009 | 01:48 PM
Ok now I understand!
The AMG cars had the staggered setup all the time, for cool looks and better stability, right?
Hvala lepo za informacija!
Old Dec 25, 2009 | 01:51 PM
PJmak's Avatar
U got it right
nema na cemu lol. Odakle si, gde zivis?? Ja sam u sacramentu CA
Old Dec 25, 2009 | 01:54 PM
U got it right
zivim u Svedsku!
U SAAB city Trollhattan GM oce da zatvarju fabrika
imam vec 35 godina u svedsku!
moj C43 imam 5 godine!
Super kola a slabi kvalitet na ovih kolima!!
Nisam zadovoljen sa auto!
http://www.garaget.org/?car=178801
Old Dec 25, 2009 | 02:21 PM
ProjectC55's Avatar
C43/55,2k11 Volvo S60 T6AWD,2k Audi B5 S4,95 Eagle Talon Tsi AWD 500+awhp
U got it right
Wow Nice Bro! How did you fit the 265's back there? I have 255's in he rear and hey used to rub. Then again I have the mono's from a SL500 on my car.
Old Dec 25, 2009 | 02:57 PM
C36 AMG
Its not only for looks or stability,, its Because the added Torque from the AMG engines needs the traction on the wider rear wheels....
Old Dec 25, 2009 | 03:32 PM
Sorry I forgot about the torque in the engine too!
I know for a fact that when I have washed my car and it's all wet, tires also wet!
When taking of gently, my car spins and loses traction on dry surface when hitting throttle gently!
I guess it's because my tires are wet and slippy but also my car is healthy!
I don't know about the wheels?
They are heavy 18 inch original Brabus monoblock V!
multipiece wheels!
Would this make the car be slower and weaker in strenght for torque?
I know if a car has a bad MAF then car, responds poor and the torque is less than 410nm!
This is not on my car I changed the MAF!
So I know it has all the ponies present when needed!
It pulls like a train!
Old Dec 25, 2009 | 05:49 PM
AMGC's Avatar
Mosselman 190E 16V+ C63S+ Abarth 595
my 18" brabus Vs were amazingly lighter than the stock 17 monos. And staggered with fatty lips is just plain sexy.
Old Dec 25, 2009 | 06:17 PM
what are you saying man?
Are my original BRABUS monoblock V lighter than stock 17 inch AMG wheels?
Is this true?
I have 225/40/18 fronts and rear is 255/35/18
They are heavy!
They feel heavy!
They look phat!
But they handle worse than the 17 inch wheels!
The steering response isn't as good with the 17 inch wheels!
The ride comfort is great on a good tarmac road!
But on smaller roads with bad tarmac thenit isn't fun driving the car, it rattles sometimes inside the cabin!
Well everything is a compromise, between ride comfort/ stiffness in shox!
Old Dec 25, 2009 | 06:41 PM
AMGC's Avatar
mine were single piece and were a lot lighter than the monos.
Old Dec 25, 2009 | 07:10 PM
ohlord's Avatar
Besides the
increased traction to the rears provided you use stagger to tune the cars characteristics for under and oversteer.
Old Dec 25, 2009 | 08:27 PM
v0ac's Avatar
C43 AMG & E55 AMG
it's impossible you run 265 in the back with a drop without rubbing
UNLESS you played with you fenders.
wich i don't wanna do,
Old Dec 26, 2009 | 01:36 PM
PJmak's Avatar
zivim u Svedsku!
nice car man
Sto nisi zadovoljan. I love mine
What are the offsets on your wheels?
I completly took out th plastick pieces that are around the wheel hole inside and I rolled the fenders on top and bottom only. Where the top of the rear bumper connects with the metal body. To be honest it rubbed a little bit with y continental 2 tires but with the michelins there is no rubbing at all. I dunno whuy, same tire size
Look above
Here is a new picture of the stance I took yesterday.
Old Dec 26, 2009 | 07:43 PM
For you fellow americans not understanding foreign language!
I'm describing my problems for my new found friend from Balkan!
I thought I was the only one from Balkan that drove a C43 AMG!
I guess I was wrong!
Well my problems had been some electrical gremlins with my transmission!
I had to change the conductor plate and the plastic o-ring plug because of oil leak!
MAF changed
Front O2 sensors changed
Clear coat peeling of at few places
HU display on climate control is ****ed up on and off!
All these problems occured less than 90,000km on the clock!
Otherwise she's been a good ***** my car!
ima auto previse frke sa kvalitet!
nisu vise kao pravi mercedesa!
posledni kvalitetni mercedes je bio 201: 190 tip i 124: E-klasse!
202 su bili dobri ili okej do 1997 godina posle sve propasti na marka MB!
Moj auto nisam bas zadovoljen zato sto imao a few rust spots!
elektronski problemi sa menjac, morao sam da promenin conductor plate,
i plug na automatic getriebe sam promenio, tece ulje predno na passengers side!
drugi problem je bio da promenin o2 sensors oba dva predni!
Nema zadni o2 sensors na moj auto!
Promenio sam MAF
Climate control display is going south!
clear coat is peeling of at certain places on inner door seal and trunk seal where the metal is folded!
Sve ovo se desavalo ispod 90,000km!!!!
Slabi kvalitet na C-klasse 202!
Inace kola ide super!
Odakle si iz Balkana?
ja sam iz Skoplje!
Old Dec 26, 2009 | 08:59 PM
v0ac's Avatar
C43 AMG & E55 AMG
guess it depends on ur drop then..
cause my drop with 255 rear on the stock 17'' mono rims..
i do rub on every little crack i can find..
you rolled your fenders i think i read before no?
you even said it yourself you did rub before lol...
maybe im crazy too
my car is lower then yours too
Old Dec 26, 2009 | 09:01 PM
v0ac's Avatar
C43 AMG & E55 AMG
but nice car btw
Old Dec 26, 2009 | 09:08 PM
tasho3's Avatar
2014 C63 Sedan
i have 255/35/18 in the back and it rubs only when i have 4 people in the car and i hit a bump other than that i have no problems and i did put my buddy's 235/35/18 front and back for a couple of days and the car handled completely different for some reason and sometimes the ECU would completely shut off and the car wouldn't shift, speedo was not working and all the lights on dash would come on
Old Dec 26, 2009 | 09:10 PM
tasho3's Avatar
2014 C63 Sedan
MAF changed
Promenio sam MAF
ja sam iz Skoplje!
1 more C43 owner from Balkan here
