1998 MERCEDES C280 WILL NOT START PLEASE READ & HELP
1998 Mercedes C280
ok well Im trading in my mercedes c280 and I was going to pull the car out of my driveway and i was slipping... so put the traction control on put it into 2nd and tryed it again .. then did it with the t/c on.. still nothing... so i go to put it back in park and it wouldnt go in park.... so long story short i take the whole shipping assembly out and there was a big piece of plastic in there... connect everything back works fine goes threw all the gears.. but the car will not start... any ideas.. i tryed disconnecting the battery for a minute or 2 but i didnt leave it off longer than that... its sitting at the top of my driveway with the battery disconnected... will that reset the computer/car... and is there anything else i need to do ?
"It will not start" may not be enough information. If it doesn't turn over, I would guess that the sensor that determines the gear selector positioning is out of alignment (IE the car doesn't think it's in park).
I have no idea what the first part of the problem was.
83 500SEC, 87 300D, 02 C32(x2), 02 C320T (x2), 03 C320T4, 03 C320T, 03 E55, 05 E320CDI, 06 E320CDI
Sounds like something isnt right in your shifter module after taking it apart.
1998 Mercedes C280
ok im sorry... it doesnt turn over.. so how could i find out what the problem is? i left the battery disconnected over night.. im going to try it in 10 minutes to see if it changed anything. but i think the car doesnt think its in park.. so how could i change that. it must be the postion of the shifter
1998 Mercedes C280
COULD SOMEONE PLEASE HELP ME.. I TRYED TO LEAVE THE BATTERY OFF.. AND FOR SOME REASON THE CAR DOESNT RECONGIZE ITS IN PARK... ALTHO IT IS... AND IT JUST WILL NOT START.. DOESNT CRANK OR ANYTHING .... I NEED THIS FIXED ASAP
Since it won't turn over while in park, plant your foot securely on the brake and try it in reverse. IF it starts, as soon as it's running put it in park. If reverse doesn't work, try neutral. If that doesn't work, try drive. The part about the brakes applies to drive as well.
Hopefully this works. If you skip the brake part, and the car starts please post pictures of the wreckage that follows. Someone may have a spare rear bumper. The rest are in it for the entertainment value.
What gear is showing in the display on the cluster when you try to start it?
1998 Mercedes C280
i tryed to put it in drive and nothing .. i tryed it in every gear.... and still nothing... and its not showing anything on the gauge cluster...my c280 doesnt display what gear u put it into on the cluster... im trying to upload a video of what is happening. if any has a suggestion please let me no!
I believe you're right, it was 00 or 01 when that started. My fault, it's been a long day ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
It might be time to take it in and see if they can establish communication with the shifter module.
1998 Mercedes C280
i dont have anyway of getting it to a mercedes dealership.. the closest one is like an hour away... could i use one of those computers that have at auto zone and hook it up and see what happens.. or could i just get a whole new shifter assembly... i could get one really cheap at my local u pull it place. i heard that might fix it... im uploading a video right now and it should be done in the mouring cause its taking forever. but like i said i really dont have the money to be taking it to a dealership... i need a way to fix it even if its for a little while :/
Location: Saratoga Springs, New York & Sarasota, Florida.
MB’s
Where are you located? You need to find a inde shop to service the car. The MB dealer will charge you more then needed.
