started tear down for paint
know why MB provides "2" Maf #s: "113 094 00 48 & 01 48", anyone got ideas whats the different between them......??
ZAYED,,
In your case it sound more like a big vacum leak. Any chance you got a leak in the intake manifold that you cleaned up? Also if the engine fire was buring with the key on it is possible that there is electrical damage to the injectors. check anyting electrical that is still on the engine when the fire took place. I was also wondering if you will run a catch can as these engine love to fill the intakes with oil. do you have plans for the old engine? I am interested in it.
Fingers crossed it will be sorted out soon. Can just the MAF lead to all these issues? The E55's MAF didn't run right, and gave a CEL. I actually don't think I tried the aftermarket one I have on had - maybe I'll as the techs to do that. But when I did use the aftermarket MAF a couple winters ago, the car ran quite oddly. It would be fine for a while, and then lead to much bucking and shaking and CEL. Going back to the original C43 ECU and those problems disappeared. I'll ask the shop to try the aftermarket one and see what's what. I'll also have my parts guy price out a brand new MAF too.
The 55 injectors were all cleaned. The guy who did the cleaning had remarked that the pattern was something different to anything he'd previously encountered, but I think he would have told me if they were inconsistently so. Maybe I'll check into that too. I suppose I could try going back to the C43's original injectors too, but that will need some more parts from out of town - namely the lower plastic washer that holds the o-ring in place.
Also, pretty sure the intake manifold was reassembled fine, though I guess it's worth looking at again. I used high temp RTV silicone sealant to reassemble the entire manifold, I can't imagine that product wouldn't be enough to hold everything together. I used the same stuff on oil pans on both the C43 and my S2000 and no issues at all. I'm hoping there are no problems with the variable length manifold bits and pieces inside. As I had posted a few pages back when I reassembled it, I had to use some silicone hose to connect up the actuator to the nipple on the reservoir. However, the diameter of hose chosen was such that it would be airtight on the manifold. That part did not show up at all on the EPC, the EPC just shows a single part number for the manifold, and doesn't break it down. That said, I suppose a smoke test or spraying the manifold with brake cleaner to check for leaks is another option, but I just don't see it. I'd like to think I'm careful enough to not have an issue like a huge-*** vacuum leak, but I suppose I'm not infallible.
I suppose also that a catch can would be nice, but I need to get the thing running right first, then take it from there. Back in my Saab days, I used a junkyard salvaged AC evap unit from some GM product and had my engine builder weld up mounting tabs and the other accoutrements to make a nice little catch can. Had a little BMC filter on top and a sight gauge on the side. Quite nice. Stuff to think about later.
I reused the 55's variable intake length actuator, pressure sensor and the secondary air injection and EGR bits. They all looked fine. At any rate, the SAI and EGR system, I would think, would not lead to such major running issues? I ran my old Volvo V70 (and my uncle who now drives it) with the CEL on for SAI without any running issues. We just clear the code once in a while.
Once I get the 55 running, I'm open to flogging the 43 motor. The only other option is to keep it and hope some CLK430 or ML430 or whatever shows up for sale with a blown motor and I can do a swap in. Thing is, you never see those cars with blown motors....
Very annoying, as I had said, to not have the car running, as my S2000 is also down at the moment with some clutch issues, and looks like I'll have to drop the trans on that to figure it out - but will re-assemble with a new, aftermarket clutch - but that's for another thread entirely...
Do your tech guys have the Star diagnosis? If not, I recommend that would be the first place to look at and check all the codes. That system should detect even a wink of the eye
Also, I read somewhere here that splitting the intake would be a major PITTA to get air tight again. Perhaps that is one reason why the disassembly is not mentioned in the WIS
I was careful with the brake booster line, looks okay. I did manage to break the 90* elbow on the plastic vacuum line but I just replaced it with a section of silicone vac hose.
Today's still a day off for us so I hope there are some more answers tomorrow.
If you have a spare intake mani handy I would try installing that too. Im not curious at all about dismantling the internal parts of the intake many so I left it aloe to avoid problems. I did clean it real good though.
And nothing is showing for fault codes or anything, so he's guessing it's a mechanical issue, ie. timing.
Hopefully will know more tonight...fingers crossed it's something that's fixable!!!
I think its an Electrical or Air issues, try to remove the Maf wire connector while the car running if any changing or shaking, as same as each of the coil
connector........
ZAYED,,
I hope it gets resolved soon. I feel your frustration after all the hard work and long hours you've put into this project.
I hope it is something simple and inexpensive that's causing all this for you.
good luck.
I'm pessimistic too about timing being off, as I don't see how it could have been. I never touched the timing chains, never had the timing cover off nor the heads, just the valve covers and that would have no effect, of course.
I'm gonna call them again at the end of the day and see what's what.
good luck.
to beat the small.....
ZAYED,,
The techs pulled the valve covers and inserted the Benz tools for checking cam timing. Apparently the cams are locked into place, and when doing so, the flywheel should be at a certain point, ie. there is a larger gap in the shutter wheel to indicate TDC. However, the gap wasn't in the right place. They eventually rotated it to find TDC, so the gap is there.
I don't see how I could have put the flywheel on wrong, and this is two flywheels now that I've mounted, the one on the 55 and the one from the 43 (which is on the 55 engine right now). They only go on one way, as there is a particular pattern with a stud on the crank.
But I guess there's no way to tell unless they open it up. Therefore, the trans is coming out and we'll see. I'll bring in the 55's flywheel tomorrow too, see what they come up with in comparison.
This is the only obvious issue that's been found, everything else checks out okay.
