started tear down for paint
What can happen is that as you trun the crank backwards the chain pulls tight and compresses the tensioner before actualy turning the camshafts. What happens then is the slack chain 'pools' below the crankshaft sprocket and fails to pick up correctly when rotated the correct way.
Its not the end of the world though, just need to undo tensioner and cam sprockets and re-align
More answers later. The trans is coming out right now, and I'll be back at the shop at lunch to see what's up. On a positive note, the new trans mount and shifter bushing will go in too. The latter was almost toast.
What do you mean by a different line up between front and rear
But the larger gap is not lining up. The front end of the motor is good, but not the rear. Weird.
One explanation is that the flywheel is not mounted correctly. But that is hard to believe given that the flywheel can only sit onto the crankshaft in one way - that is because of the dowel on the crank. So something has to be really buggered up there, or the flywheels are different - but they aren't because I checked the part numbers.
It's a puzzle. Hopefully will know more in a few hours...
I think it's got to be something else. But I too feel your pain and am anxiously waiting on the outcome. Thanks for sharing...
And I never mucked around with the crank or cams, the only things I did were to change the front and rear main seals, and the valve cover gaskets. So the tech is not faulting any work I did (which is pleasing to me) but the bloody thing is still not running!!! Grr.
He's going to do a compression test and see if he can find anything. Large differences would tend to show something. And I suppose he will also rotate the engine enough to see the casting numbers on the cams to see if they were indeed mixed up somehow.
Do you know surely, if this Engine was only firing or waterfall.......??
ZAYED,,
I had pulled a Carfax report on the car before I bought the motor, and it showed it was written off due to an engine fire. This was confirmed when the engine arrived, with the wiring harness mostly melted. Later inspection found that the fitting on the fuel rail to the fuel line was bent out of shape.
before moved it from the car but little ticky sound comes from the lift Head,,, but after arrived, we discovered some salty
hiding under the Head gasket, open the Engine, woowoow, like swiming pool in Heltonia beach...!!
ZAYED,,
But that still doesn't make sense - if the timing is fine, there is no reason the motor shouldn't run. I am at a loss....
I'm out of ideas. I hope they figures something out. The tech is convinced it's not the MAF, but I've asked him to indulge me and to try out one of the three I've left over there.
Boo.
Boo.
I know that damn feeling (average down to loosing challenge), every cent you spend & every second from your mind thought
DESERVE to have a fantastic Ride.......
ZAYED,,
If it makes you feel any better, this has been a few days for you. When I did my swap, it took a month and half before I ever heard the engine fire, due to trying to figure out how to hack the MB computer and code it to a Crossfire. There were many times I thought to myself, "why did I ruin a perfectly good car" It was very depressing and I have felt your pain first hand. Stay patient and keep at it. You will find the issue.
His discussions with another experienced tech (his old shop foreman from his dealership days) was that the motor is firing late, hence the excessive unburnt fuel into the cats. The pipes (and not just the cats) got hot enough that some of the fabric heat shielding/sound deadening underneath got singed, just from ambient heat.
Now the only things left to try to pursue are: a) the MAF - he's going to try the aftermarket one, but he's also pessimistic that's not the issue; and b) trying to find differences between the various 113.980 motors. I have heard anecdotally that the later motors had a half point bump in compression, can anyone confirm? Also can anyone confirm that there may be different cam profiles after a certain year or engine serial number? My 55 is out of an '02 E55, so it should be one of the last of the NA E55s, but I wouldn't have thought there would be major differences in the engines between the various model years?
All "M113.980-81-82-84-86" 55s sharing a same Cams & timing things, but not so sure about compression......
ZAYED,,
It's making less and less sense now!!!!
