started tear down for paint
I have C32 and there is a full size spare...
Nice thread.... love it... sad to see you didnt sucseed to put 55 in 43.... hope you will....
I drove w202 before w203 and i think that the build quality is better in w202...
Of course w203 is more modern... but i think as a car for dd w202 is better...
car,, {GOOD LUCK}.......
ZAYED,,
Before yesterday when my friend came to me, i noticed a strange vibration in the Engine, i spray a contact cleaner to the intake manifold, it has
a leak from the EGR side, we went to my friend garage, after he removed the intake manifold, WaaaaW..
, there’r a leak from many places..
;1) EGR small hoses leaks & the gasket is soo bad
2) Bottom injector o-rings with one broken injector #6
3) Little cracked in the base of the manifold(which the gasket seated)
4) Cracked in the vaccum resonance valve( that controls the linkage doors)
5) Leak from the connector( above the Actuator)
6) Change-over valve not working
7) Most of the vaccum lines cracked
* After we washed the manifold we open it and see a lot of water inside it, also the linkage is loosing & gab in the main pin( that moves the all
doors), we press the linkage pin to make sure NOT plays again, and then clean the surface & put a special silicone, closed the manifold & leave
it 5-6 hours, to let the silicone seated properly,, after solved all these problems, the car flying like a Falcon..........
ZAYED,,
From Zayed's last post, it seems like that car had more issues than mine. I have new EGR hoses, new vacuum lines, resealed everything, triple checked the function of the actuator and linkage - still a mystery!
I'm waiting for spring and then will get a buddy or two to lend a hand in further diagnosis. Such a pity.
At any rate, responding to DRB's query in another thread, there hasn't been any action on the 43. I still don't know what's wrong exactly, but I haven't been spending time trying to figure it out either. It's one thing to work on a car in the garage when it's -10 or so, it's quite another to be doing that when the car is sitting outside - and the C43 has been sitting on my patio since October or November.
I still don't think the issues are related to the intake manifold. I think there must be some issue with the electronics or wiring harness. I'm going to enlist the help of another mechanic friend to give it a whirl - but later. Despite what I've said about wrenching in the winter months, I did actually start making some money helping out some of the local S2000 guys. I helped a guy remove and replace the softtop on this car, and a mechanic friend and I just finished a supercharger install on another S2000. Next I'm hoping to line up a big brake kit install on another S2000. But first, this coming Easter long weekend I'm wrenching on my S2000 again, putting in a new clutch.
After that...well...my wife and I are expecting our first child in early June, so I suspect I will be quite busy with the new addition as opposed to car stuff! But hopefully I will get a chance to sort out the C43. I am determined to have it run again, but once it does, it will go to my parents for their fun car. Good to keep it in the family - I put waaaay to much effort (let alone money and parts) to see it go elsewhere. So once it runs again, maybe next summer, I will get the 55 back in there....
I hope the 43/55 gets solved finally. I understand your feelings and hesitancy working in a non heated environment during the Canadian winter
So, as long as you’re dropping the trans are you tossing in a lightweight flywheel? Already have one? S2000s already rev. A lightweight flywheel should make it rev live a 600 sportbike. I've had lightweight flywheels and can tell you from experience - that is money well spent.
Another “must have”: Do you use a trans jack? If you don’t have a trans jack and have never used one, they make the job a lot easier. The two biggest benefits are not having to bench pressing the trans and no front seal leaks because the trans "accidentally" rested on the input shaft while being R&R’d. I bought a mechanical scissors style one ages ago. I don't remember what I paid, but it was inexpensive. There really is no going back. Ask around, one of you friends may already own one. If so borrow it.
Going back in is a resurfaced OE flywheel (14 lbs) and a Science of Speed sport clutch kit:
http://scienceofspeed.com/products/d.../Sport_Clutch/
I also have a new rear main seal that I may get in there too. Going back to OE because the aluminum was a bit too racy for the street. Honestly, Science of Speed's own 'street' lightweight flywheel is 11.5 lbs, so I can live with the 2.5 lbs difference and don't want to go back to the Fidanza.
I also picked up a Motive Products power bleeder, with adaptors for use on both the Honda and the AMG. Should cut down on bleeding hydraulics considerably.
Trans jack - you know last time my buddy and I just bench pressed the trans into place. It's not too heavy, not like an auto trans. There's a sale on at Princess Auto right now though, so I might pick one up anyway (but then again, I want to grab a hydraulic press for half price so.... )
My buddy surmised maybe some issue with fuel, so we looked at the fuel pump relay - it is working. He then came up with the idea of spraying a combustible fluid (we used brake cleaner I had) into the intake. This managed to get the car to run - still very poor idle - ~750rpm - but the right bank cat wasn't glowing, and we ran it for about 5 minutes like that. It would still suddenly die if we tried to apply too much throttle.
He brought over an expensive OBD2 scanner, one that showed live readings. We saw ignition varying from about -20* to -3* BTDC - not sure if that's right or not. We also saw that most of the sensors giving inputs were indeed doing so, ie. crank and cam sensors, MAF. A few codes did come up - misfire cylinders 1 and 6, random misfire - these three disappeared after a little while of idling. One persisted, however, MAF circuit issue. I don't know if this was related to the brake clean spray into the throttle body, but this code did not disappear. We opened up the connector to the MAF and nothing obvious there, but potentially there is an issue in the rest of wiring to the ECU?
That's something to follow up with, but a quick WIS search didn't pull anything up, ie. how to check the MAF wiring circuit, with continuity or voltage figures. I need to dig more - but if anyone knows of a precise WIS document to search, do let me know! Also, I need to check the fuel pump again, and its wiring. I did not realize, but as the fuel system is returnless, fuel pressure is varied by varying the voltage to the pump, correct? So perhaps there are some issues there.
That's all for now...not too much progress, unfortunately, but some areas to chase. Wish me luck. Any suggestions are very welcome.
I will look through the WIS and see if I can find anything pertaining to the MAF wiring circuit, if I do I will definitely post it.
https://i.imgur.com/slZHE.png
ZAYED,,
should read 14.5v,, comes & go to the ECU & back to the TCU,, i changed the wire completely, from the ECU to the air mass connector, everything back to
normal & MAF missing issue solved........
