Front bumper hanging...
Anyone have a DIY on removal and securing. The bumper was pulled when wifey backed off one of the concrete stops in a parking lot. It was hanging way more than shown, but I was able to push it up some. However the sides are still protruding - is there a clip or fastener that keeps the sides in?
The mounting bracket on both sides may have been dislodged or torn (hope not) and remount/retighten the bolts securing them to the side of the bumper.
It's not that hard really. Just be careful you don't tear up the inner fender linings as they get brittle over time.
Good luck.
Good luck.
I did jack up one side and looked under for a minute...but didn't go any further as I have to run to a cookout in a min. And if I were to start, one thing would of lead to another and I'd be under the car for the rest of the evening...
I had the exact same situation with my car - previous owner had hit the curb a few too many times and cracked the bumper side mounting channels. I did a rudimentary repair with stainless steel safety wire, but the whole bumper wouldn't line up properly - hence the need for the new inner reinforcement.
If you do go that far, keep in mind that in order to fit the C43 bumper skin, the inner reinforcement has to be trimmed in certain areas. I found the instructions in the WIS, but they are also detailed here:
https://mbworld.org/forums/c-class-w...fogs-w202.html
(just so whoever is reading doesn't have to click around any more than is necessary! )
The trimming took 5 minutes with a dremel. The reinforcement is all plastic anyway. Piece of cake.
Good point, could be the exact same part with the AMG logo = $$$$$. As I stated earlier mine were cracked (not terribly) and I "fixed" them with super glue. Took out ALMOST all of the flare but I will need new ones to make it look like it just rolled off the line. Just another part on the list to refresh my black beauty.
I did use regular super glue. The cracks were on the plastic guide rails on the bumper support. It worked great for a couple months and then one of my neighbors nudged my bumper and it broke the glues bond
