SOLVED: Cruise Control Magnetic Clutch Disengaging
Old Jul 9, 2010 | 02:05 AM
jumph4x's Avatar
W210 DRFT BNZ
EDIT: A member of BenzWorld has created the ultimate guide to fixing this. His handle is GDC and I believe his name is Greg. With his permission I am reposting his article\walkthrough in PDF form to help all of you guys. See attachment.
Here we go again, Part III.
Enjoy. You are looking at an M104 ETA (Electronic Throttle Actuator) enabled throttle body assembly with the integrated harness and connector.
Need to buy 20- and 22- gauge automotive wire before I can complete this job.
Having just done this job, I can give a bit of advice as well:
  • It is best to avoid using the original rubber harness sleeve
  • I used 20 gauge wiring and it worked very well
  • Home depot has the supplies to help you weatherproof this harness: Waterproof Electrical Tape (self-amalgamating electrical wrap) and Liquid Tape (for sealing the connector and the harness entry point into the throttle body)
File Type: pdf
Old Jul 9, 2010 | 02:47 AM
mbsickness's Avatar
1996 C36
Wow, I can't believe the wiring is that bad. I recently changed my ETA due to stalling and an inoperative cruise control.
Old Jul 9, 2010 | 02:51 AM
jumph4x's Avatar
W210 DRFT BNZ
I know! Its such a shame - these cars are fantastic mechanically speaking...
Oh well. I know I won't be buying replacement harnesses of any kind. Will craft all my own.
Old Jul 9, 2010 | 02:54 AM
DRBC43AMG's Avatar
From: CH = Land of mountains, cheese, chocolate and watches
These harness problems on the C36 are mind boggling
Old Jul 9, 2010 | 07:59 AM
jumph4x's Avatar
W210 DRFT BNZ
I'm starting to think they aren't specific to C36s.
However, C36s are older, so they bring the problems out quicker.
The M104 ETA problem applies to E320 and S320s as well as early C280. Not just W202 but also W124.
Old Jul 9, 2010 | 11:17 AM
mbsickness's Avatar
1996 C36
At least in my case of the ETA was replaced on my 94 C280. I might have to slice open the harness on the ETA now as curiosity is getting the best of me.
Old Jul 9, 2010 | 11:25 AM
503C43 ////AMG's Avatar
1999 C43, 2008 P30 E63, 2014 SQ5, 2024 Model Y Performance
I hope none of this happens to my C43 (KNOCK ON WOOD) it is unreal how crappy some of the harness's are in the C36. What ever happened to German craftsmanship???? I applaud you in your discoveries as well as your how to's on harness rebuilds. Keep up the good work
Old Jul 10, 2010 | 12:32 AM
MarcusF's Avatar
2002 CLK430
The bad harnesses aren't C36 specific. The 1993 through 1995 model years of all MB and Porsche cars were impacted.
This is a 1995 911. This is known to fry a DME (ecu) and other electronics in a 911.
Old Jul 10, 2010 | 12:42 AM
FRIGHTENING...... Looks like spaghetti
Old Jul 10, 2010 | 08:52 AM
DRBC43AMG's Avatar
Seeing that lot of spaghetti, now you can understand why the car isn't running well....
Old Jul 10, 2010 | 04:03 PM
jumph4x's Avatar
W210 DRFT BNZ
Updated the first post everyone. Peep it.
Old Jul 15, 2010 | 11:51 AM
jumph4x's Avatar
W210 DRFT BNZ
Please rate the thread if it is of any use whatsoever.
Old Jul 15, 2010 | 04:16 PM
DRBC43AMG's Avatar
Rates a top score for the C36 users IMO and should be a STICKY !!!!!!!!! Mods please note
Old Jun 2, 2012 | 04:21 PM
hovman's Avatar
Mercedes w124 e320
Hello to all.
Do you have the throttle connection scheme(pinout) for 000 141 57 25 (VDO 408.226/4/1)
My car mercedes w124 e320 1995 M104.992
please send me hovman@rambler.ru
thank you
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
