C43 '55' swap thread
Old Jul 17, 2014 | 10:24 PM
  #226
cm60k's Avatar
Mounts from M113 55K, are brilliant, try them..
ZAYED,,
Old Jul 18, 2014 | 12:38 AM
  #227
benzslo's Avatar
C43 5.4, ML320CDI, Fords
i'm using oem 43 mounts, they work great.
Old Jul 18, 2014 | 06:03 AM
  #228
KJI3jflarryfe93's Avatar
ZAYED,,
M113 55K engine mounts do they fit c43 engine?
Old Jul 18, 2014 | 11:16 AM
  #229
cm60k's Avatar
Yes sure, i'm using them NOW..
ZAYED,,
Old Jul 18, 2014 | 05:19 PM
  #230
PJmak's Avatar
How do you find them different?
Old Jul 18, 2014 | 05:41 PM
  #231
cm60k's Avatar
I feel they are more stiff, when the car in N and accelerate, Engine not moving like the C43 mounts...
ZAYED,,
Old Jul 19, 2014 | 06:44 AM
  #232
ZAYED,,
hey brotha
no modifications needed to fit E55K engine mounts to c43 engine, only to fit then be happy?
Old Jul 19, 2014 | 10:13 AM
  #233
cm60k's Avatar
Sure bro., no any mods.,,
plug & play..
ZAYED,,
Old Jul 19, 2014 | 10:14 AM
  #234
DRBC43AMG's Avatar
Sure bro., plug & play..
ZAYED,,
Never with Kowalski.....
Old Jul 20, 2014 | 12:35 PM
  #235
PJmak's Avatar
The stock mounts seem fine. Engine vibration was one of the things that was never an issue.
If these last longer then i guess its worth it. Are they same price?
For an engine swap i guess its good to have heavier duty mounts
Old Jul 20, 2014 | 12:48 PM
  #236
cm60k's Avatar
+1,
When i swap to 5.4l, i thought about stiffer mounts, i found better idea to go with 55K mounts,
i believe MB needs to put more heavy duty mounts to handle 463hp vs 306hp>>354hp..!
ZAYED,,
Old Jul 20, 2014 | 03:20 PM
  #237
Pagz's Avatar
C43 w/clk55 Organs
Hello Zayed,
Do you feel any more vibration with E55K mounts?
Does the engine sit higher than stock?
C43 mounts seem fine but there is some engine deflection when quickly changing direction... long time ago I changed C230 M111 mounts to M113 ..the whole car felt much tighter with very little increase in vibration
Cheers,
Old Jul 20, 2014 | 07:37 PM
  #238
cm60k's Avatar
Hi Paul,
How's going with your C43/55..?
honestly; i'm not that sure about Engine height with stock mounts,
no any kind of vibration with any driving positions at all..
ZAYED,,
Old Aug 22, 2014 | 04:29 PM
  #239
raw1879's Avatar
Mercedes C55 AMG
w210 E55 facelift had different engine mounts to c43/clk55 they might be stiffer
Old Aug 22, 2014 | 04:33 PM
  #240
raw1879's Avatar
Mercedes C55 AMG
Originally Posted by benzslo
Power on the n/a 55's should be about the same on all, different ratings are likely due to variations in intake and exhaust.
I just recently finished up rebuilding my w210 E55 motor. New piston rings, rod bearings, valve job, new chains and guides, oil pump, everything resealed, plugs, all OEM parts, etc. It has nickle and dimed me but it's done and I'm dropping it in this Thursday. I can't wait! Couple old hotrod tricks during the build too
I saw a guy on the club MB UK site on his rebuild he swapped the water outlet to the other side head. I don't know if this is due to being right hand drive... but this is not needed for USA cars.
I also used an oil pump from a later m113 motor, it is underdriven by 4 teeth compared to my 2000 e55 motor. matching pump chain needed.
that was me
Old Aug 22, 2014 | 04:45 PM
  #241
cm60k's Avatar
98 to 2002 using the same mounts, #: 202 240 29 17" as optional of "202 240 44 17" or "49 17"..,
do you know if there are any special mounts version or something for facelift..??
ZAYED,,
Old Aug 23, 2014 | 11:48 AM
  #242
ECTurboGSX's Avatar
98 C43, 15 Alfa 4C LE, 18 Tesla Model 3 DM Perf, 08 Duc S1000, 02 Duc 998, 98 Duc 748, 01 Miata
From what I've been able to tell, the E55K motor mounts are the same part number as the S55, including the NA version from 2001 and 2002. As far as geometry, I couldn't tell you yet as I haven't ordered them but I plan to give them a try.
Old Aug 23, 2014 | 11:52 AM
  #243
are you buying genuine parts from stealership or aftermarket mounts?
please let us know if they fit perfect?
Old Aug 23, 2014 | 03:21 PM
  #244
cm60k's Avatar
Try them, will NOT regret..
ZAYED,,
Old Aug 25, 2014 | 06:32 PM
  #245
PJmak's Avatar
Any 5.4 motors around bay area and sacramento for around a grand?
Old Oct 6, 2014 | 02:47 PM
  #246
PJmak's Avatar
2000 ML55 m113.
Any pros or cons over the engines from other 55 amg n/a models?
Im looking at one with 111k for $1200
Old Oct 7, 2014 | 04:48 AM
  #247
DRBC43AMG's Avatar
I think the only differences are with the oil pan and probably oil pump and sump pick up.
Old Oct 14, 2014 | 09:04 PM
  #248
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
and you just use the ones from your 4.3 right?
Old Oct 15, 2014 | 06:14 PM
  #249
DRBC43AMG's Avatar
From what I've heard and read yes.
Old Oct 16, 2014 | 05:29 AM
  #250
do you remove these parts from the c43 engine and refit them to E55 engine?
these parts are they not the same on both engines?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
