Warped Brake Rotor
Old Sep 21, 2010 | 04:04 PM
nick3453's Avatar
1999 Mercedes-Benz C43 AMG
Question Warped Brake Rotor
Hey guys...I have a warped front brake rotor on my 99 C43 AMG and I need to get it replaced. Do I have to use the OEM vented rotors? Or can a different kind be used? Also, does anyone know where I could find some good prices on the rotors? Thanks!
Old Sep 21, 2010 | 04:12 PM
ohlord's Avatar
$224
each directional rotor
www.autohausaz.com
you can't replace just one.
Did you check run out to confirm warp?
Old Sep 21, 2010 | 04:45 PM
nick3453's Avatar
Ive been getting shakes in the pedal and steering wheel when i brake...so I took it to the shop and they test drove it and confirmed it was a warped brake rotor.
Old Sep 21, 2010 | 05:33 PM
ohlord's Avatar
Takes a lot
to warp a rotor.
Get a second opinion or have them show you the run out on the rotor.
Tie rods or cupped tires on the inner tread can also cause those symptoms.
Worth double checking before spending over 5bills only to find you did the wrong repair.
Old Sep 21, 2010 | 06:03 PM
nick3453's Avatar
thanks ohlord. I'm going to go get it checked out again.
Old Sep 21, 2010 | 06:45 PM
nick3453's Avatar
ok...i got a second opinion..and once again its been confirmed that I have a warped rotor. So I guess I will have to get some new ones. Wheres can I find some good deals?
Old Sep 21, 2010 | 09:10 PM
ohlord's Avatar
www.autohausaz.com
get new pads also and be sure to properly bed them in.
Easy diy job
also be sure to put the paste on the back of the shims.
Old Sep 22, 2010 | 02:18 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
How did you manage to warp a rotor?
I've run my rotors down to 27mm (min spec 30mm) and still used them on a track day and I haven't been able to warp them!
Old Sep 22, 2010 | 05:00 AM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
usually it's overzealous lug nuts or cold water on hot rotors rather than hard use on the brakes.
stoptech has nice webpage on how to bed-in. side-effect varies depending on pads; the hawk hps were smok'n like my car's on fire, but the mintex extreme (don't get these, won't stop squealling regardless of what u use, lube, shims) just smelled a little.
Old Sep 22, 2010 | 06:44 AM
DRBC43AMG's Avatar
Warping a rotor is pretty tough thing to do unless it got very very hot and caught cold too quickly.
On top of all the other recommendations when changing rotors (always in pairs) stated above, I would include the change to stainless steel flex hoses (if not done already) and a change with new good quality fluid and a full bleed of the circuit
Old Sep 22, 2010 | 08:37 AM
Saaboteur's Avatar
eclectic assortment of cars
If there's enough meat in the rotor, you can always have it machined - the brake wobble should go away. Best check, or have checked, how much meat is in the rotor though. There are certain tolerances that have to be kept in mind.
Old Sep 22, 2010 | 09:14 AM
tmaguire's Avatar
2005 CL55 AMG, 2004 S430 4matic, 1988 560SL, PRIOR: 2000 E430 4matic, 1994 E320 Coupe, 1999 C43 AMG
Warped rotors are a VERY common problem on W124, W202 and W210... (the models I've owned). Machining is a possiblity but I wouldn't go that route..
Old Sep 22, 2010 | 09:16 AM
tmaguire's Avatar
Though I haven't used them I've heard good things about Disc Italia.. http://www.brakeworld.com/catalog.as...G%20%28W202%29
Old Sep 22, 2010 | 09:58 AM
nick3453's Avatar
When I first bought the car I took it to get the brakes replaced and the shop told me I had a warped rotor and showed it to me as well. They machined both of my front rotors even after saying these rotors normally couldnt be rotated. It drove fine after that for awhile but then I had my tires replaced on the front and I believe...not positive...that the tire shop may have cranked the lug nuts to tight when putting the wheels back on which could have caused it to warp again. Idk...could be another reason, but it didn't seem to start till after that.
Old Sep 22, 2010 | 10:09 AM
ohlord's Avatar
you DON'T MACHINE
MB rotors they don't have enough material to machine after being in use.
The ones on your car are directional so they can't be swapped side to side.
Whoever did your brakes did you a real disservice in the first place.
Get the parts diy the job might take you a hour or two even if you never did a brake job in your life.
You definitely don't want to add the potential of cracking by installing high priced drilled rotors.
Old Sep 22, 2010 | 01:04 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
I have them on mine !
Old Sep 22, 2010 | 05:47 PM
steve s's Avatar
i have since switched to slotted, but here's a look at cracks in my old brembos (320x28)
Old Sep 23, 2010 | 03:17 AM
DRBC43AMG's Avatar
The rotor looks seriously worn (outer lip) and has no (safe) life left in it. I see two cracks
Old Sep 24, 2010 | 04:46 AM
steve s's Avatar
yeah, 40k miles plus 2 track days on a front heavy fwd
