camber wear
I just had the car in for an alignment, as my mechanic noticed a bit of camber wear while he was doing the brakes. Nothing excessive mind you. Took it to local tire store, and all they could do was adjust toe settings. No camber adjustments for vehicle, front or rear. I was told to take it to the dealer, they have a bolt kit for this?
Wonder what others have done for this, if anything at all?
My car sits on Eibach springs and either number 1 or 2 pads. Haven't confirmed which.
However, I recommend you read this thread: https://mbworld.org/forums/performan...ml#post1387106
and just buy one on ebay last week (upper rear arm) for 200$
hope it's not to hard to fit
after that you've got non ajustable camber on front : 1.20-1.25
front toe adjustable
ajustable rear camber : put between 2° and 2°30' (advice)
rear toe adjustable
Installing those would almost make it an identical match. L to R.
Remember, any more than 1/2 degree difference between L to R will cause the car to drift towards the side with the most positive camber.
