Opinions Please...Spark plugs which ones?
After 11 years, I hope the plugs come out without any issues.
http://www.densoiridium.com/faq.php
Biggest caution (make your life simpler) MAKE SURE YOU GET EXTENSIONS THAT LOCK YOUR SOCKETS) - Sears has them
sparkies are next!
buying from autohausaz, great products and prices!
should i go ahead and do wires too?
i don't know the last time they were changed
Unless the wires are obviously damaged just leave them. They rarely fail since they are just copper leads with resistor ends.
Do get 3 new coil boots tho and lots of dielectric grease.
rjp
because losing enough mpg to where you can notice it is not good
It is an easy DIY - I did a POST on here a while ago, you just have to take your time and don't yank on any of the high-tension leads. I would highly recommend you obtain ratchet extensions that lock your sockets.
I used Denso Iridiums - you will never go wrong with the OEM Bosch.
Thanks The plugs are treated
More plugs are damaged by using it and not needed so why risk the damage
I also have magnecor Kv 85 for our car and I can let that go for $120.00!!
The only time I would advise against it use is for O2 sensor applications....
ZAYED,,
